first 360/390 build..
#31
Not sure how it could have run long enough to cause crank damage, as the engine would not run once the sprocket moved more than 10 or 15 degrees, maybe less, maybe a little more, but certainly not a full or even half turn.
That said, is this the 360 crank? If so, find a 390 crank and move onward and upward....
#32
#33
#34
#35
just went down to the machine shop to check on my parts. they said that the crank in unuseable because the timing gear on the crank has spun. therefore the crank is slightly smaller where the gear press fits on??? does this sound legimate? can I get an oversized timeing gear? if I need to get a new crank where can I get one cheapish?
Scifi266
03-07-2008 01:33 AM
DJOHNSTON78
24
12-20-2007 11:43 PM
allwthrrider
09-05-2006 11:32 PM
jseim44
19
05-19-2004 09:26 PM
Rat wagon
04-21-2003 11:09 PM
