Help, it is the trans or engine???
My truck has been running flawless for over a year, then on Monday morning it started acting weird. I can't figure out if it's the engine, or transmission, or both. I am not getting any engine codes.
Here is what it is doing: As I move from a dead stop, the transmission feels like it is in a gear to high, by 35 to 40 mph it is already in top gear. Between 30 and 40 mph the transmission hunts for the proper gear to be in, and it shifts hard. Gas mileage is way down since this started.
Also, when I come to a stop, I am having to use more brake pressure than in the past. And, just as the truck is almost stopped, a heavy vibration can be felt though-out the truck, almost feels like I am driving over a miniature cattle guard crossing. I threw the truck in neutral once while stopping, and no vibration. It's almost like the transmission is not downshifting at stops.
It was the tranny. Shift module warped, torque converter bad, and 3rd gear solenoid wasted. According to the shop, the 3rd gear solenoid was causing all the problems, which in turn took out the other parts. Per the shops recommendation, doing a complete rebuild since the tranny has 135,000 miles on it. $2,800 later and my truck will shift again, at least they are giving me a 24,000 mile/ 2 year warranty.
zeppelingto
04-18-2012 08:38 PM
Big Rig
06-28-2006 10:41 AM
