Rattle at Idle - Intermittent - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 11-27-2014, 08:27 AM
kenmandoo2's Avatar
kenmandoo2 kenmandoo2 is offline
kenmandoo2 is starting off with a positive reputation.
Just noticed this intermittent rattle at idle, in park.
Noticeable rattle - comes and goes.
A/C not turned on and not engaged when rattle happens.
Kind of sounds like it's coming from between front of engine area.
The rattle comes on as the engine seems to be changing rpm's at idle......kind of like the a/c is engaging and the idles to up a little and the rattle starts for a second or two and then the idle goes down and there is no rattle?
Something is causing a draw on current and the idle seems to adjust and the the rattle starts. The idle drops down and the noise goes away.....this cycles while parked, engine at normal temp.
My gut tells me this gen3 may have electric cooling fans that are kicking on and off and I'm just not used to this rattle/vibration???? I'll get under there soon and confirm the noise. The idle pulley looks to have a little play in it too.
Help- '99 V10 Rattle- Videos in thread 69_Eliminator 1999 to 2016 Super Duty 6 01-18-2017 08:44 AM
engine rattling noise Fordperson Explorer, Sport Trac, Mountaineer & Aviator 1 03-28-2016 01:08 PM
Mysterious Rattle Coming From the Engine genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-01-2015 03:00 AM
Mystery Rattle in crankshaft area CazicT Escape & Escape Hybrid 5 06-28-2014 09:38 PM
Weird "rattle" '01 Excape XLT 3.0 WB4IUY Escape & Escape Hybrid 3 05-31-2014 07:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
