Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 11-27-2014, 07:49 AM
viperbaron viperbaron is offline
viperbaron is starting off with a positive reputation.
How to operate the manual hubs
I recently purchased an F-250 down in TX and drove it home to CO. It is my first for auto/locking hubs, first for an electronic switch on the dash to engage the 4WD, first diesel and first turbo engine.
What is the procedure to operate the front hubs? What exactly is different between the "Auto" and the "Lock" settings? Can I leave the hubs in AUTO for highway driving and will they engage when I go off road and turn the 4WD **** on the dash? Do I have to be in Natural first to engage the 4WD?
I have the BFG All Terrain tires and they don't grip anything; snow, sand, dirt, pavement etc.
Thank you!
Old 11-27-2014, 11:19 AM
TosaFords's Avatar
TosaFords TosaFords is online now
TosaFords is gaining momentum as a positive member of FTE.TosaFords is gaining momentum as a positive member of FTE.
Most of the time you can leave them in Auto. They will automatically Engage when you the the switch to 4WD. It make take a few seconds for them to engage when you first turn the switch. They will also Disengage when you flip back to 2WD. Again, it may take a bit for them to actually disengage but don't worry they won't do any damage.
No need to be in neutral while switching between 2WD and 4WD. You can do this at any speed. It recommended to not switch above 50MPH though because you could cause damage.
The LOCK position on the front hubs works just like a normal manual hub. It locks them in so they are always locked. This can be useful if you are stuck and can't get the front wheels spinning to engage the hubs Automatically using the dash switch. You can drive with them locked all the time if you want. Many people do. Just be aware that the front axle/drive shaft will be spinning the entire time as well even though the transfer case is not engaged.
Unless you get stuck or there's a problem with the Auto mode you are fine leaving them there. They will engage and disengage as needed when you turn the switch on the dash.
__________________
Ryan
2012 F-250 XL CC/LB 4x4 - 6.2L V8 - 3.73 E-Locker - FX4 - 35/12.50/17 Toyo Open County MTs - ReadyLift SST 2.5" Front / 3" Rear Lift
Old 11-27-2014, 11:42 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Quote:
According to Ford you can engage 4 High up to 50 mph, and I have and it works.
To engage 4 low you must be stopped, in neutral, and have your foot on the brake pedal.
Also, the front wheels dont need to spin to engage the auto hubs; but it helps. Occasionally, especially if there is a vacuum leak, the auto hubs won't lock. This is whereits nice to have a manual override.
Sent from my Samsung Galaxy Tab 3
__________________
- Trey PAA Member #110
2002 F250 XLT CrewCab Short Bed 4x4 7.3L
My How-To Video Library
SoCal Chapter Member (Join us HERE)
Similar Threads
Manual Hubs Frankievespa Excursion - King of SUVs 4 01-30-2011 09:48 AM
how to engage 4WD dbmstr124 6.0L Power Stroke Diesel 10 03-11-2008 10:56 PM
4X4 Operation rls911 New Member Introductions 1 02-26-2007 12:20 PM
Another 4wd not working question johnnybecool Super Duty & Heavy Duty 8 02-20-2007 08:52 AM
Push button 4X4 with manual hubs? live2hunt Offroad & 4x4 4 02-17-2007 06:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
