View Poll Results: Which trans??
'93, W250, Cummins, 4x4, Automatic
0%
'94, 2500, Cummins, 4x4, Automatic
100.00%
Voters: 1. You may not vote on this poll
Which Cummins engine/trans combo to use?
Old 11-26-2014, 05:49 PM
79Supercab's Avatar
79Supercab
79Supercab is offline
I need some advice. I have a choice of buying either a:
'93 W250, Cummins, 4x4, Automatic
or
'94 2500, Cummins, 4x4, Automatic
Both have slightly modded pumps, exhaust, intake.
I'm putting it in a '78 F250 Crewcab 4x4. It's a daily driver with only about 5% of the miles hauling this (When the Bronco is on my car trailer I weigh in at about 16,000 lbs):
Knowing that which transmission should I get?
With the whole non-lockup overdrive issue in the '93, should I go with the '94?
Let's not take into account the differences in the pump, cost, mileage, etc.
Ryan
Old 11-26-2014, 06:07 PM
93-331-29PSI's Avatar
93-331-29PSI
93-331-29PSI is offline
Go with the 94. You'll be happier with the p-pump over the VE pump. 94 turbo is the hx35 which is better than the 93 turbo. Transmissions will be similar but he 94 will handle more torque and iirc has a lockup converter. Good luck and if you pass send me the info.
Old 11-26-2014, 09:05 PM
79Supercab's Avatar
79Supercab
You want the info on the '93?
Old 11-27-2014, 05:09 AM
93-331-29PSI
Yes please PM me the details.
Realslowww
02-05-2017 08:54 PM
fordtrucknut
39
03-31-2011 08:53 PM
4x4k20
09-15-2007 01:56 PM
sorajt
12-06-2004 12:46 AM
Quick Reply: Which Cummins engine/trans combo to use?
