Brake Lights On for No Reason?
Hello,
I just bought a 55 F100. Original braking system. I have had it less than 24 hours. For some reason I don't understand, the brake lights come on every once in a while, while it is sitting in the garage, all by themselves! I will go into the garage to get something and find the brake lights on! Then I will step on the brake and release and they turn off. Doesn't happen all the time. Does anyone have idea what is causing this and what the solution is?
Thanks,
Gary
Thanks,
Gary
Received 4,130 Likes
on
Welcome to the board!!
I'm guessing that it has the original style hydraulic brake light switch that threads into the brake line near the master cylinder. Its very common for these switches to go bad and start staying on.
Luckily the switches are readily available and you should be able to pick one up at your local parts store.
Good luck
Bobby
Good luck
Bobby
I was having this issue but it wasn't happening randomly; only after I drove it. Mine was from what Bigwin56f100 said above....
I needed to turn the bolt below the brake pedal under the truck as it was causing my truck to keep pressure on the brakes and hence, the brake lights staying on after driving it. If you get under your truck on the driver's side, you will see the master cylinder. On the end of it, is the brake light switch. You will see wires go to it. Before you go to too much trouble, you may want to just check these that they are not bare and touching...good luck. And welcome to the forums. There is lots of info here and friendly people to help.
The pressure type brake switches can go bad in three ways. I've seen all three.
1.They can corrode internally and turn the brake lights on at random.
2. They can fail to turn the lights on.
3. They can require way too much pressure to turn the lights on. You want the lights to come on with slight pressure such as a slow rolling stop.
Brake lights staying on - Thanks for your input
Thanks everyone for your input on why my brake lights are staying on.
upon further inspection, I see a lot of rust on brake lines and master cylinder and have decided to replace the master cylinder and brake lines. Hopefully, through this process, the brake lights on problem will be solved as well.
Thanks Again,
Gary
Thanks Again,
Gary
Nobby
06-26-2021 01:17 PM
jacampbell
08-08-2018 05:06 PM
old broke prospector
07-23-2013 11:15 PM
