Switch to manual hubs do i have to cap the air lines off
Old 11-30-2014, 11:37 PM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
Originally Posted by Vince79vette
where is this solenoid.
Right fender just off the end of the vac box
Old 11-30-2014, 11:38 PM
superdave02f552
Originally Posted by hasteranger
Why unplug the solenoid if it doesn't hurt anything just to leave it alone?
It WILL effect the operation of the heat controls while IN 4x4 only.
Old 12-01-2014, 07:13 AM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
This is all that I've noticed, been running Warn's for a long while now. A/C will blow out of everything if 4x is engaged, otherwise no issues. Air goes back to normal operation when switched back to 2wd.
Old 12-01-2014, 09:49 AM
Splash67's Avatar
Splash67
Splash67 is offline
Just put a plug in the line at the fitting on the frame rail and go on with life...
Old 12-01-2014, 01:44 PM
superdave02f552
not just a/c what ever you select for output. and the system is designed to default to defrost only in the event of losing vac.
no matter what you do something somewhere needs to be done to plug the hose/s if you want everything to work like the day it was made
Old 12-01-2014, 07:07 PM
Krazee Matt
not just a/c what ever you select for output. and the system is designed to default to defrost only in the event of losing vac. no matter what you do something somewhere needs to be done to plug the hose/s if you want everything to work like the day it was made
It doesn't get cold enough here for heat, lol. My experience is AC only. But thanks for the correction, good looking out.
Old 12-01-2014, 10:02 PM
mecdac's Avatar
mecdac
mecdac is offline
Yes, a buddy of mine's F150 A/C blows through the defrost vents.
Come on man. Fix your junk.
Originally Posted by mecdac
Only if you want the A/C - Defrost to work properly.
Old 12-02-2014, 06:02 AM
sammie0126's Avatar
sammie0126
sammie0126 is offline
This is a two minute fix....
Old 12-02-2014, 09:02 AM
Vince79vette's Avatar
Vince79vette
Vince79vette is offline
what size nipples did u use.
Old 12-02-2014, 04:19 PM
sammie0126's Avatar
sammie0126
Honestly I have no idea, I dug around in the tool box until I found one that fit and would hold a vacuum. That's what I used.
Old 12-02-2014, 06:01 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
Thank you.
Old 12-02-2014, 06:22 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
I currently have 4.88 gears in the rear and 3.73 up front. To avoid any accidental binding situations I just unplugged the electrical connector from the vacuum switch/solenoid on the right front fenderwell. Everything works HVAC wise as it should and now if it gets switched to 4 High or Low on the dash the transfer case will do it's thing but the hubs won't lock and bind up the driveline. Handy now too for when I am backing the TT into spots as I use 4 Low (now 2 Low in my case) to have better control and it helps to avoid trans front seal overheating and leakage. Once I get around to swapping in the 4.88 front axle I will reconnect the vacuum switch/solenoid and add a dash switch and relay to allow for 2 Low again when desired.
  #28
Old 12-03-2014, 01:39 PM
hasteranger
Does anyone have a good write up with pics on pulling hubs? I have a short time window Sunday morning to pull mine and would like to make sure there are no surprises.
  #29
Old 12-03-2014, 02:37 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
  #30
Old 12-03-2014, 09:29 PM
Vince79vette
It is craxy easy man. First time doing it and took me 5mins per side. There is a video on youtube on it.
irydasteelhorse
1999 to 2016 Super Duty
01-16-2016 09:56 AM
BarryOwings
03-27-2014 04:19 PM
big315
02-05-2008 08:34 AM
thor96
12-03-2007 10:47 PM
TERSEJR
Offroad & 4x4
11-24-2003 09:33 PM
Quick Reply: Switch to manual hubs do i have to cap the air lines off
