1992 460 E4OD 4R100
1992 460 E4OD 4R100
I have a 92 F-350 4x4 crew cab with a 7.5l and E4OD transmission. The overdrive planetary is destroyed and upon further inspection just about all of the hard parts are pretty worn out. In my research of this forum and other internet searches I found that the 4R100 is basically a newer version of a E4OD. My question is can I take all (or most) of the internals of a 4R100 and put them in my case? I have a 4R100 out of a 2004 Navigator that I plan to use as a donor. I know the tail shaft is different and something about a drum that runs a sensor. Can I use the valve body and/or solenoid packs? Are there any other parts I shouldn't use? I have not picked up the donor transmission yet but will over the weekend. I'm getting the whole trans for $100 and if all I get to use is the planetaries and a few other hard parts I will be money ahead. Thanks in advance for any responses.
There were dozens of updates to the E4OD over the years, but I am not an expert on transmissions. You may want to post further down the page: Clutch, Transmission, Differential, Axle & Transfer Case - Ford Truck Enthusiasts Forums
I started to tear into the donor transmission and found a broken snap ring that did some pretty good damage. I was able to get a replacement out of a 99 5.4 f-250 4x4. This one has a tag that says it's been rebuilt by Ford. When I took this one apart the fluid was nice and red, almost nothing on the magnet and the clutches look good. I'm just going to inspect the parts and re-install without buying a rebuild kit. Should I (can I) use the valve body from my 92 e4od or the valve body from the 99 4r100? The new planetaries are 3 pinion aluminum, I'm pretty positive I want to upgrade the o/d planetaries with a steel 4 pinion. Should I upgrade the other planetaries with the 6 pinion or are they less prone to failure?
jgbailey57
11-26-2014 05:13 PM
RRE101
06-14-2010 07:57 PM
mudog715
04-10-2005 09:36 PM
