Rear fuel tank filler
Old 11-26-2014, 01:01 PM
TJ62's Avatar
TJ62
TJ62 is offline
Hello my (new2me) 69 swb 2wd has had a PO remove the cab mount and install a rear mounted fuel tank.
its not bad but the filler pipe is routed on the left side between the top of the leafs and the frame.
my thought is eventually I would like to do a DJM 3"& 4" lowering kit.
This will not be possible with that filler running through there as the DJM kit has relocated leaf spring mounts. I have seen the filler doors through the bottom of the bed, this is what I might do.
Does anyone have one of these and is it a good thing or a pain in the ***?
Old 11-26-2014, 02:50 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Welcome to FTE newbie
There have been numerous tanks mounted back there with numerous filler locations on here. I suggest you use the search engine top o' this page and research 'em. That way you can find out which tank you got and what fabbing was involved on installing the filler location you choose then. You may change your mind on your current choice.
Old 11-26-2014, 02:55 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Consider this:
... and here is the rest of the 69 F100:
Old 11-26-2014, 03:00 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Originally Posted by HIO Silver
Consider this:
Now THAT is ingenuity! What was used as a cap Hio? And how was it sealed?
Old 11-26-2014, 03:04 PM
HIO Silver's Avatar
HIO Silver
IIRC, it was either one of those pop-up caps or the kind with a two-prong key. I recall seeing them in Yogi's: Yogi's Inc. Parts for Street Rods, Muscle Cars and Classics
I think Speedway Motors offers a couple of versions too..
Old 11-26-2014, 07:00 PM
f100today's Avatar
f100today
f100today is offline
search "pop up gas cap" on ebay. There are a bunch
Old 11-30-2014, 12:08 PM
1loco's Avatar
1loco
1loco is offline
They are frequently used on motorcycle tanks. Look in any motorcycle catalog like JP and you'll see dozens of styles.
Ikestang
07-16-2022 08:02 PM
old22fan
01-22-2018 12:40 PM
resonateur
07-31-2017 02:23 PM
69supercj
10-12-2014 03:18 PM
MP&C
01-05-2009 12:56 PM
Quick Reply: Rear fuel tank filler
