Gas tank won't fill up all the way HELP PLEASE!!
It takes some trial and error to get the fuel line at the right depth. The easy way of doing it is to make the clamp just loose enough for the hose to still be able to slide, and then put the hose down lower than you think it needs to go. It should give you a little resistance when you put the sending unit back into the tank. Then pull it back out, tighten the clamp, and you should be good to go. The showerheads just push on to the metal tube and that's it. Easier is a matter of opinion.
Okay so basically the shower head route would be a little bit more money, but easier (in a way) while the fuel hose may be less money but more trial and error? I plan on doing the fuel hose option first and if my problem still remains I guess I will have to go the shower head route.
Those little pieces of the broken showerhead will get sucked up once you extend the pickup, Try to get as much of it out of them as you can, Some of the pieces may be larger. When I fixed my pickups the tiny pieces stopped up my lift pump, I recommend you add clear 3/8 prefilters to each tank and keep an eye on them for a while.
So however you had planned on cleaning out the old pieces of the showerhead by dropping the tanks, it can be done either way.
It would be no different than if you dropped the tank. It will just be much easier on you as far as fighting super tight spaces and save you a lot of time. Pull the bed and you can do both tanks at once.
82POS
12-08-2004 03:14 PM
Loopie
23
03-03-2003 01:36 PM
