1968 f100 240?
Please explain your wants and expectations a tad better. FordSix and Trozei are two of the I6 gurus on this forum. They prolly will chime in soon. I believe there is also a forum here specific to the I6's. Look on our home page and check it out there also.
I can't just blindly suggest things for you to do to your engine without knowing how far you want to take it.
When my spark advance and retard diaphragms went, I had mine set to like 20 or something LOL.
Cheap tricks, efi dual exhaust manifolds, chevy six rockers, high energy ignition.
Do the ignition with a DurasparkII dist., a coil from an efi and a GM module. Easy to wire up and works great (also cheap) If you shop around a little, you could do all that for $200-$300 and have noticeably more seat of the pants feel.
I've juiced up a few 300s and owned a couple decent running stock 240s. But nowdays, I probably wouldn't dump money into another one when I can get a lot more bang for the buck with a V8. The one single thing (IMHO) that I ever did for the most gain was a good clean up porting job.
So the best advice I'd give, if the basic engine is sound; Get another 240 head and port it good, get the newer style 300 stock intake so you can run the bigger YF single carb, and do the other above mentioned mods. You would have an engine that runs good and probably gets better mileage. Also maybe shave the head a little.
1962F100dude
10-18-2013 04:12 PM
Double K
11-24-2008 01:16 PM
