Blown head gasket?
Old 11-27-2014, 12:13 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Pull the plugs. See if any are shiny and clean. If your losing coolant, and its intruding through the gasket, you may be able to notice it in the cylinder just by checking the plugs.
if you find a wet plug, chances are high you fou d the leak at that point. Another old school method is to rotate the engine and find TDC for each cylinder. Then using an air hose fitting and compressed air, thread it into the cylinder plug hole. With it at TDC, the valves closed, if you start pushing air into the cylinder, if the gasket is compromised, then you will see air bubbles start to form at the filler neck. I did this before when I didn't have access to a coolant pressure tester and it showed that the gasket was shot on the passenger side if my 302. It ended my headache of blowing coolant out and the water being clear when flushing. Everytime I drove it, coolant would blow out the coolant reservoir tank.
Be sure that if temps are dipping below freezing, add some coolant or your problem will become huge if the block freezes.
Even the head gasket is compromised, don't fret. The 300 isn't that hard to repair. Heavy though, if you end up pulling the head, it needs to be milled for straightness as any 300 head that may have overheated always should be checked.
Old 11-27-2014, 12:38 PM
copen93's Avatar
copen93
copen93 is offline
Originally Posted by Shadow944795
Tester you can get at autozone, you pay thrm some money for it and you take it and do what you need to get done and you take it back after you are done and get a refund and you have 90 days to take it back. Use that tool and see if it leaks down and if it does try and fine where it is coming from. Could you drive it like that? Most likely yes but will it do this truck any good? Nope not a bit if it is having gasket issues.
Ok I got the compression test, I couldn't even hold the pressure, so much air was escaping at the top hose where it meets the radiator, I bought a new hose, fingers crossing that's where the air is coming from.
Old 11-27-2014, 01:19 PM
copen93's Avatar
copen93
copen93 is offline
Originally Posted by NotEnoughTrucks2014
Slow down a bit!
You seem to have at least 3 problems here;
Your truck overheats.
Your truck has an oil leak.
Your truck has some sort of exhaust leak.
Yes, it is very frustrating to have these sorts of problems with limited funds, but tackle them one at a time. $1300 is not going to buy a problem free truck, well, at least most times. $230 can go a long ways towards fixing problems if you do the work yourself and resist the urge to throw parts at it.
I would say the most pressing issue is overheating and, if I read your post correctly, you do not have a functioning temperature gauge. Fix this first. Simple check, ground the wire at the sender and see if the gauge moves in the cab. Make sure the connection is good. If you need parts, try the wreckers. Once you have a working gauge, you can see if your cooling system repairs work. Is it leaking coolant? Have you checked the thermostat? Overheating can be, but does not have to be a head gasket.
Could this be causing the air bubbles at the radiator cap and overheating?
valkyrie9901's Avatar
valkyrie9901
valkyrie9901 is offline
No mis info from me Joey......Been a Ford mechanic for MANY years and fixed MANY trucks where they overheat because the owners pulled the t/s then complained of overheating....They can't figure it out either. If coolant circulates too fast and isn't restricted, the radiator can't cool it fast enough it overheats.......JB.
Old 11-27-2014, 03:40 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
interesting ... my 40 years of maintaining/repairing my own vehicles (and a few others) would never have led me to think that this was possible, but i will defer the superior knowledge and experience of someone who does this full-time and say ... "i stand corrected, sir" .
Old 11-27-2014, 06:47 PM
valkyrie9901
Not wanting anyone to "stand corrected" but if you ever have a vehicle that is easy to remove a T-stat, pull it and leave the cap off . Watch how fast the water flows through the radiator. Increase the RPM's and it really cranks it through. At least it was that way in the older cars and trucks. I'm not superior, just something I have encountered many times as people did not like how hot the cars ran when this emission stuff went into effect and they pulled the T-stats. I better be quiet as I am giving away my age!!!!
Old 11-27-2014, 07:00 PM
joey2fords's Avatar
joey2fords
i have no problem with being wrong... it has happened before ...and i am glad to have learned something. it just always seemed more logical to think that the faster the water got away from the combustion area, the cooler it was going to run. but, as i say, if someone with more experience knows otherwise then i accept that info gratefully.
Old 11-27-2014, 07:10 PM
valkyrie9901
The coolant flows too fast through it to absorb the heat and to fast through the rad. to dissipate it. I don't really understand it either..........JB.
Old 11-27-2014, 08:13 PM
Garage Rat's Avatar
Garage Rat
Garage Rat is offline
It's all about pressure, fluid under pressure has a higher boiling point which aids in heat transfer from engine to coolant, that's why if you open the rad cap on a hot engine it erupts everywhere, you suddenly relieved the pressure and the fluid instantly boils.
Old 11-27-2014, 09:56 PM
copen93's Avatar
copen93
copen93 is offline
So you're saying with the radiator having the hole, or hopefully only the hose being messed up the air is getting in and thus allowing no pressure and overheating the truck?
Old 11-27-2014, 10:55 PM
Garage Rat's Avatar
Garage Rat
Air doesn't come in through leaks in a cooling system,the air inside is just the absence of coolant, but let's rule out leaks and t stat first. Your video I'm guessing was you pressure testing the system, if you hear a hissing sound spray soapy water in the area you suspect, it should blow bubbles revealing the leak.
Old 11-28-2014, 01:26 AM
timbersteel
Same about psi. If the radiator cap is bad, it'll never build psi and the engine will allows run hot. I had that happen on a '92 S10. Did everything, including water pump, come to find out it was only a $8 radiator cap.
  #28
Old 11-28-2014, 08:29 AM
Garage Rat's Avatar
Garage Rat
When I refer to pressure that's what I mean, psi is the unit in which pressure is measured, and yes, a rad cap that won't hold pressure will cause that problem, you can pressure test the rad cap to verify this.
airsurf
1997-2006 Expedition & Navigator
02-11-2010 07:00 PM
blksmith
04-22-2007 12:49 PM
ford_f100_custom
11-03-2004 11:11 AM
epdc
05-18-2004 07:47 AM
Border3899
07-11-2003 01:28 PM
Quick Reply: Blown head gasket?
