2006 f250 crew cab
6.0
98k on truck
Tires - stock size
Around 58 to 65 truck has a bad shake. Tires look smooth.
Any thoughts. Front end parts I should be looking at? Has anyone had this problem?
2006 f250 crew cab
6.0
98k on truck
Tires - stock size
Ball joints first. You can lift the wheel off the ground and use a crow bar to lift in the ball joint seam and see if there's play.
Also Check your tires for delamination as this can create a harmonic vibration at certain speeds too. U joint/s next.
2 or 4 wheel drive?
I had the same thing on my stock tire sized tires and it was actually the tire wear/balancing i found out as i got my 35's put on. They felts smooth but the tire shop said they had a weird wavey pattern worn into them and 2 were out of balance.
I would first have the tires checked out for proper balance. Does it seems to shake the wheel or the entire truck? One less expensive but more labor is to swap the tires from front to rear an see if the shake changes. For instance I it feels like it's hopping a little and you swap tires and then you can feel it in the steering wheel or vice versa then You know it's a tire issue. You can then only switch one side front to back an morrow it down to which tire. If it makes absolutely no difference then you can start trouble shooting the truck. In the speed range you have given it leans towards a tire issue.
I would assume its a tire issue i had the same exact thing, if you go faster does it get worse? If i remember right mine got really bad like couldn't control the wheel at around 75 then 80 would get better (i dont go faster than 65 usually just tried it to try and diagnose).
I have the shaking problem at the same speeds but don't feel it in the steering wheel. I've had ball joints replaced, wheels bead balanced, entire driveline checked, with no resolution. This seems to be a common problem with Super Duties.
