Slow cooling
Old 11-25-2014, 06:27 PM
DieselVol's Avatar
DieselVol
DieselVol is offline
Slow cooling
Truck as below. I'm running a "cold front" on it, just as I did last year. This year despite the cold weather, it's taking forever for the EGTs to get below 400. I typically cool it to 385 before I shut it off. Coolant is full, nothing else has been done recently to the truck. Any ideas why cooling is so much slower this winter than last?
Old 11-25-2014, 07:16 PM
04badford's Avatar
04badford
04badford is offline
Thermostat stuck? what's the trans temp look like? the only other thing would be Water pump
Old 11-25-2014, 07:31 PM
DieselVol's Avatar
DieselVol
Tranny acts normal. You may be onto something with the water pump idea. The problem seems somewhat intermittent, cooling normally sometimes and very poorly others. The other day, I had to add coolant for the first time in nearly a year when I found the reservoir almost completely empty. I filled it back to the normal level, only to find the reservoir completely full the next day. Is that that the pump working intermittently?
Old 11-25-2014, 07:39 PM
04badford's Avatar
04badford
It could be , I know the blades will chip away so full operation wont be the same, what is your oil coolant temps? are you sure your not loosing coolant internally?
Old 11-25-2014, 07:46 PM
DieselVol's Avatar
DieselVol
I have the BPD external oil cooler, they're normal, and I don't think have anything to do with this picture. I don't know for a fact that I'm not losing coolant internally, but I do have studs, new head gaskets 2 years ago, and I've been monitoring the coolant pressures fôr about 2 weeks with no pressure over 15 and no response to hard acceleration.
Old 11-25-2014, 07:58 PM
04badford's Avatar
04badford
How long has the thermostat been in and is it OEM?
Old 11-25-2014, 08:15 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
You're asking about EGT and the topic immediately went to ECT?
Josh
Old 11-25-2014, 08:34 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
These turbos are very TUFF Temps don't seam to have much effect on them
I would worry more about overheat then Cooldown especialy if your already down to 400-600* range upon shutdown
The only time I would worry about proper cooldown is if youjust climbed Mt Everest pullen 15K you wouldn't want to shut it down immediately
Theres Tons of folks out there with no EGT gauges that just shut down no matter the temp and have 0 turbo problem from excessive heat
IMO an EGT gauge would be more for keeping an eye out for an Overfuel condition from bad inject maybe a Hot Tune
Old 11-25-2014, 08:41 PM
BLADE35's Avatar
BLADE35
So could it bethe case you have an Aftermarket Turbo???
Old 11-25-2014, 09:02 PM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Nothing wrong with 400° at shutdown....maybe your temp probe or gauge is acting up, hence the difference?
Old 11-25-2014, 09:12 PM
DieselVol's Avatar
DieselVol
Nah, stock turbo.
Old 11-25-2014, 09:15 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Josh
I was thinking the same thing....
Old 11-25-2014, 09:16 PM
DieselVol's Avatar
DieselVol
Josh
I see your point. EGT is the concern and I assume that you're saying that poorly circulating coolant will not affect EGTs?
Old 11-25-2014, 09:50 PM
DieselVol's Avatar
DieselVol
Agree on the 400. The problem is getting it there. It'll take 2 minutes to go from 500 to 400 sometimes. It never took that long to cool from ANY temp a few weeks ago.
Old 11-25-2014, 10:00 PM
MisterCMK's Avatar
MisterCMK
No, it isn't going to affect the EGT
Quick Reply: Slow cooling
