Groaning Noise While Turning
UPDATE
Visited my local dealer today for regular service and included this issue. Two separate techs drove the truck and couldn't re-create the sound. The one said he heard something as he was backing into the bay (as I can hear when backing and turning) but it wasn't anything that was too alarming. The other one drove it around, made multiple turns of varying degree and speed and could not get a response.
While driving home I distinctively heard it twice out of the 7-8 turns I had to make. It is raining today, so I wondered if that had anything to do with it being quiet.
The second older tech did throw out the clutch pack fix as something that happens with the 150 in this generation but they both had a look at it and said everything looked like it was in good shape and nothing was worn out. They were really helpful and to have two people take a look said a lot.
So the good news is I only spent about $50 for oil, filter and a touch up paint pen, but the bad news is there is still this noise I'm paranoid about or I'm just generally losing my mind. I'll continue to monitor it and update everyone on what (if anything) comes of it.
~Mike
~Mike
The best way to recreate is to come to a stop on an incline, then accelerate and turn hard left or right. What you are trying to do is make the outer rear wheel turn as many more revolutions as possible than the inner rear wheel. This more fully engages the clutch packs than taking normal corners, and thus best exposes the issue. If you do not get the sound when doing this, it could be something else entirely.
Best of luck determining the issue. When I had my 2nd set of CPs replaced at 59K (out of standard 36 mos/36K mile warranty), Ford refused to acknowledge the issue, even when reproduced as above with the technician in the vehicle with me. But when the tech learned that I had an extended warranty, he immediately agreed that the CPs were the issue, replaced them, and the problem was solved. I have been on these packs for over 100K with no further issues...
Well, I've waited to see if I was over exaggerating and...I'm not. The issue has been the same if not worse. I'm looking to take the truck in Saturday and have it looked at. I'll be taking the tech on a drive this time as well. The fact that 2 separate techs couldn't hear what I'm experiencing leads me to believe they're either deaf or trying to cover up what may really be going on, as others have eluded to.
I'll keep you all updated.
~Mike
~Mike
No kidding! I've seen this movie before! Maybe I'll get lucky this time?
Cavs,
I've experienced similar scary noises from my 2012 Ecoboost. Three times now. It was fixed twice (under warranty) with two very different issues; but the gremlin is back. My symptoms were exactly as you describing: a groaning noise from the front end (sounded almost like a loud electroninc or hydraulic pump cycling).
The first time, the 4x4 was not disengaging. They disassembled the transfer case and found the clutch assembly had seized. They replaced the entire clutch assembly and armature and 7G362 (whatever that is) and the problem disappeared.
The second time, I started hearing a very similar groaning noise. This time however, it was not restricted to when I was turning. It took a couple months, but I eventually started to loose my brake pedal on cold starts as well. This time, they found that the brake vacuum pump had shorted and they replaced the pump. Again, the noise disappeared after the repair. (
seems to be becoming a pretty common problem with the F150 ecoboost)
Now the noise is back, but I haven't been able to pinpoint it. It's been backI to the dealer once and I got the standard "could not duplicate noise" response. I've been waiting to get a better indication of what is causing the problem before wasting a day of my time taking it back in. I guess I'll have to take it back in three more times before I can get it addressed.
I hope you can get some resolution on Saturday. Keep us all posted!
How many miles are on your truck? I'll investigate some options to assist.
Crystal
Crystal
So what's the verdict? I have the very same issue, groaning/grinding noise during a slow right turn. Three failed attempts to have dealer recreate the problem. My issue happens infrequently but seems to be more frequent during colder temperatures (40 degrees and below). It's difficult to pinpoint the source but seems to be coming from driver side front wheel area. I know it's not my imagination playing tricks on me because 3 different passengers have experienced it with me.
It's doubtful that it is related but, 2 days after driving the truck off the lot with 0.7 miles on the odometer, there was brake fluid leaking from the front driver's wheel. Dealer said it was a bleeder valve that was left loose from the factory. Shortly after at 5-6k miles I had to have the dealer turn the rotors due to major warping.
2013 SCREW Platinum Ecoboost 30,000 miles completely stock
#28
#29
So what's the verdict? I have the very same issue, groaning/grinding noise during a slow right turn. Three failed attempts to have dealer recreate the problem. My issue happens infrequently but seems to be more frequent during colder temperatures (40 degrees and below). It's difficult to pinpoint the source but seems to be coming from driver side front wheel area...
Crystal
#30
