may latest project 1955 MARMON HERRINGTON F100
how about these tires for the MH rig?
http://www.ebay.com/itm/4-new-Buckshot-wide-mudder-p78-16-original-buckshot-Co-op-33-inch-nylon-/271686421511?pt=Motors_Car_Truck_Tires&hash=item3f41c5cc07
They say not for high speeds, like that will every happen. the rear tire on the truck now is a 29" and these are 33" what do you think?
on
4 New Buckshot Wide Mudder P78 16 Original Buckshot Co Op 33 inch Nylon | eBay
They would make an awesome studded winter set
for the Bronk.
#28
so now that puts me to these and would I "have" to run tubes?
http://www.ebay.com/itm/191404903417?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Stu what about these? on my stock rims?
http://www.ebay.com/itm/Coker-Vintage-Truck-and-Military-Tire-900-16-Blackwall-71014-Set-of-2/331363968441?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27710%26meid%3D9eea962a8e104d7c9dc8980868ba6f00%26pid%3D100005%26prg%3D11385%26rk%3D2%26rkt%3D6%26sd%3D191404903417&rt=nc
#29
Kevin - I'm unclear why you'd need to run tubes in the 6.50" tractions listed in the Universal on-line catalog, but the next bigger size (7.50x16") is listed as tubeless. Nothing about the wheels require use of tubes. A call to Universal or Coker might answer it.
The 9.00 x 16" is too wide for a 5.00" rim, spec is 6.5". We have, though, seen the 7.50 x 16" NDTs mounted on the 5.50" wheels on Rod Kruithoff's below F-2 MH. You might get away with them on 5.00" rims. Stu
https://www.universaltire.com/truck-...itary-ndt.html
Edit - and as I think about it, my F-3 MH's manual shows there were two optional wheel widths, a 4.33" and a 5.00". Both were spec'd by MH for a 7.50 x 17" tire. Stu
