rear differential leaking
What gasket is leaking? I don't think I've ever seen a leak from the cover gasket, but pinion seal leaks are common. No the gears won't fall out, but as soon as the cover comes loose, a couple quarts of stinky gear oil will pour out. It would be worth your time to head over to youtube.com and find a video on changing gear oil in your truck so you have an idea of what you're doing. There are a ton of them.
The capacity depends on what axle you have, but a SRW sterling 10.5" holds 7 pints.
Check and make sure the differential cover did not rust through, not a hole but seepage through surface rust toward the bottom as you may need a new cover. Mine did that after only being 4 years old. Get the serial number off the tab on the rear end and use that to buy the correct silicone and full synthetic gear lube. There should be no gasket. When you fill the rear-end only fill up to where you can stick your pinky into the hole to the first joint and touch the gear lube.
so I checked it out and it is seeping through the cover. So I ordered one from ebay, but it was the wrong one. I did not realize there are a few different ones. Does anybody know the part number for it from ford? It is a 2000 ford F350 5.4 v8 gas 4wd and has 12 bolts on the differential. In order to exchange it the seller said I need a part number from ford.
on
'78F250351m
18
08-16-2013 07:46 AM
slow3v
10-06-2011 09:04 PM
