Scan gauge II Injector contributions?
Old 11-25-2014, 12:26 PM
rattleNsmoke's Avatar
rattleNsmoke
rattleNsmoke is offline
Does the Scan gauge allow you to see your individual injector contributions? My engine lopes and smokes a lil' and clacks like crazy when it's 20 deg or so. I'm running Rotella T-6.
Mike
Old 11-25-2014, 12:41 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Unfortunately it won't.
2006 F350 4X4
Old 11-28-2014, 07:47 AM
rattleNsmoke
Thanks for the reply. What's needed to check the injectors, a Ford scanner?
Old 11-28-2014, 07:49 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Ford IDS I think is the only thing right now that will do a true contribution test but I could be wrong.
2006 F350 4X4
Old 11-28-2014, 08:04 AM
78fordman's Avatar
78fordman
78fordman is offline
Sounds like a little bit of stiction, try some archoil and see if it gets better. You can also polish your spool valves and get that cold clatter/miss out of it instead of replacing injectors.
Old 11-28-2014, 08:57 AM
87crewdually's Avatar
87crewdually
87crewdually is offline
2006 F350 4X4
I use a Snapon Solus scanner.
Old 11-28-2014, 10:17 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Yeah--I should have clarified only units like ids and solus (probably a few others I can't think of at the moment)
2006 F350 4X4
Old 11-28-2014, 11:05 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Snap On Solus can run a contribution test, go manual and shut off individual cylinders?
Josh
Old 11-28-2014, 11:18 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
Josh
My Genyses III would not but I don't know on the Solus. It came out a couple of years later so it may be capable.
Old 11-28-2014, 12:10 PM
Bullitt390's Avatar
Bullitt390
If Solus is anything like Modis it's pretty much useless for a real contribution test. Even AE provides better feedback.
Guarantee it isn't anything like Ford IDS.
Josh
Old 11-28-2014, 05:27 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Josh
Josh I don't know if the boys at snappy got it working right yet or not.
There was some chat about it but I think the best way to read that
is with the Ford IDS or the clone.
Sean
Old 11-28-2014, 06:11 PM
Bullitt390's Avatar
Bullitt390
Sean
That's what I observed with Modis. An uneven firing at idle showed a flat line for contribution.
Josh
Old 11-28-2014, 08:24 PM
rattleNsmoke
Thanks guys. It looks like off to the shop I go.
Old 11-28-2014, 10:54 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Josh
Ford must have some type of copyright deal on the
algorithm. The reason I say that is I don't think it would
take a lot to reverse engineer the one that the IDS uses.
So it stands to reason that they have to adapt and change
it so they don't get into hot water over the copyright. The
luck of far has been dismal to be blunt.
Sean
Old 11-30-2014, 10:25 AM
zhilton's Avatar
zhilton
zhilton is offline
AutoEnginuity with the Ford enhanced bundle will do contribution tests; or at least my 2011 vintage does.
Software:
AutoEnginuity Enhanced Ford Expansion - Riffraff Diesel Performance
Software & cable:
AutoEnginuity Total Ford Enhanced Bundle - Riffraff Diesel Performance
I vaguely remember Cheezit making a comment in a thread somewhere (years ago) that AE-Ford would do almost everything IDS can do except for some odd test. I know I've been able to diagnose cracked injectors on my 6.0L and recalibrate a speedometer on a 7.3L power truck. I haven't tried the FOB/chipped key set-up that AE-Ford supports...yet.
Quick Reply: Scan gauge II Injector contributions?
