'51 F3 Synchro Transmission
  #46
Old 05-19-2015, 09:18 AM
novafreak69's Avatar
novafreak69
novafreak69 is offline
UPDATES....
Thought that I would post a few pics of updates to my project...
Obviously I don't rebuild Split Housing rear differentials every day, so I am having to build some specialized tools for removing the pinion bearing cup and the pinion support bearing. I have a mill which will make removing the rivets fairly easy. Should be going back together tomorrow.
  #47
Old 05-19-2015, 05:13 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Thanks for the update. I appreciate any pictures you can post of the ring and pinion change. Eventually I will re-gear my F-2.
  #48
Old 05-19-2015, 06:13 PM
novafreak69
troubles. ..
Right now having trouble getting the pinion bearing cup out of the housing. I do not have the proper puller to get it out... and not sure you can purchase it anywhere. Any help anyone could give would be appreciated. I have a small 4 ton Porto power on the inside pushing on the pinion shaft and it has not budged even withe adding some heat to the housing around the cup...
  #49
Old 05-20-2015, 05:02 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Here is another thread where a 4.11 set was installed, maybe it will give you some ideas: https://www.ford-trucks.com/forums/1...onversion.html
  #50
Old 05-20-2015, 11:29 PM
novafreak69
update... finally got he pinion bearing cup out... it was close with the portapower... Just needed something a lil extra... I made a toll to pull on it a bit.. did no take much... one it moved a lil the portapower pushed it on out... here are some pics...
  #51
Old 05-21-2015, 05:35 PM
novafreak69
uho....
After assembling the rear end... the gears are really tight.... there is no adjustment other Than the pinion bearing pre load.....right?
  #52
Old 05-21-2015, 07:10 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Ford had no adjustment other than pinion bearing pre-load. The champ quick change guys, who your gears were made for, do have adjustments. The shim the carrier bearings on the carrier, they shim the side bells on the center section (they have two side bells, not just one like us), and they verify gear pattern. You may need to get creative with shimming.
here is a link that discuss setting up a champ axle:
pages 65 & 66: http://www.wintersperformance.com/20...%20Catalog.pdf
and another link with some champ axle tech tips:
http://www.franklandracing.com/techtips.aspx
Thank you for the pictures.
Last edited by 38 coupe; 05-21-2015 at 07:17 PM. Reason: add links to Champ rear axle setup
  #53
Old 05-21-2015, 08:25 PM
cstempert's Avatar
cstempert
cstempert is offline
  #54
Old 05-22-2015, 08:30 AM
novafreak69
Hmmm...
I have that manual CSTempert... I will look at the other one... But After getting it together and oil in it... I ran it for a bit on the lift and it does not howl... does not seem to be as tight... The drive shaft is a lil tighter (too long) than I would like... but it was that way before I did all this... I will get the brakes bled this evening and take it out for a test drive and see how it drives and see if it howls or anything...
  #55
Old 05-26-2015, 09:13 AM
novafreak69
After Filling fluids and driving the truck for as bit ( 1 mile) the rear diff loosened up a bit... with no noises... Transmission shifts GREAT... Parking brake works GREAT... all in all it was a great project... AWESOME to see a survivor in such great shape...
The owner kept asking me if he should restore the truck and told him NO WAY!
Thank you everyone for all your help and advice while doing this truck... I think he wants to rewire the truck next...
CSTEMPERT.. You da man!
  #56
Old 05-26-2015, 04:51 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Can you post more pictures of that truck? I am a sucker for unrestored (or restored...) F-2 and F-3 pickups.
Also, I find it interesting that the license plate is hanging from the bracket the factory uses when you have only got one tail light, but the tail lights are attached to other brackets.
  #57
Old 05-27-2015, 07:01 AM
novafreak69
License Plate Bracket
I had to use the factory light and license plate bracket in conjunction with the new light brackets because the new brackets raise the lights. The license plate bracket would not work with the new ones because the license plate hit the side of the bed. I dont have many more pics... yet... but I think the owner is going to want the truck re wired soon... sooo I will prolly be back on here askin about wiring... and get more pics.
Kazoo
11-19-2020 12:14 PM
F-1
04-17-2016 12:50 PM
48fordf3
05-18-2005 10:47 PM
blessedby6
Bronco II
09-26-2002 01:23 AM
Quick Reply: '51 F3 Synchro Transmission
