'51 F3 Synchro Transmission
Old 11-26-2014, 06:07 PM
cstempert's Avatar
cstempert
cstempert is offline
[QUOTE=I am also interested in installing a T-98 in my 50 F-3. very interesting about welding material onto the mounting ears of the transmission. I suspect the the T-89 is longer than the T-19. My fear is if the T-98 body fits between the bell housing and the transmission crossmember. Also, about how much was added to the ears. Replies to this appreciated. thank you, patrick/QUOTE]
It's kind of hard to say. You almost have to measure and see where it wants to land.
The truck I worked on had the holes moved outward about 1/2" I also had to shim it about 5/8" up in the frame with a piece if solid bar it's all thru holes so not difficult
Old 11-27-2014, 08:22 AM
cstempert's Avatar
cstempert
Happy thanksgiving
Old 11-29-2014, 12:01 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Often overlooked is the Tremec T176 4 speed. Because of that the price can be attractive. It was used by Ford, Jeep and GM. The Jeep version used the Ford bolt pattern. Advance Adapters may have the parts that you need (see http://www.advanceadapters.com/tech-vault/tremec-t176/). It doesn't have the trans mounted ebrake but you could easily solve that with a Ford 9" rear axle which would solve a few other problems as well.
Old 12-04-2014, 12:51 PM
novafreak69's Avatar
novafreak69
novafreak69 is offline
Still looking...
I have been unsuccessful in finding a t-98 or a suitable replacement for this spur gear transmission... Any help in finding something would be GREATLY Appreciated!
Old 12-04-2014, 01:57 PM
fladoodle's Avatar
fladoodle
fladoodle is offline
Where are you? If it was in your profile you'd probably get more people that would speak up. I've got one that's mine and I have access to some more, maybe some from a 51-52.
Old 12-04-2014, 02:54 PM
schoo's Avatar
schoo
schoo is offline
I have a parts t98 but in cali you could try novak transmission in Utah or border parts in san diego
Old 12-04-2014, 03:35 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I checked with Advance Adapters and they said that the T176 (Tremec) should work but they don't sell transmissions. I called Novak Conversions and Dave (dave@novakadapt.com) said that he would recommend the T19 (Borg Warner) as the T176 parts are getting hard to find. This would give us a very strong, fully synchronized 4 speed box with a top loading shifter that should not require modifications to the trans cover.
Old 12-04-2014, 04:57 PM
schoo's Avatar
schoo
schoo is offline
t19 is lot better tranny and synchro granny jeerers use them a lot
Old 12-04-2014, 06:41 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Are you planning on using your pickup as a heavy duty truck? If not, you don't need a four speed transmission.
Old 12-04-2014, 08:43 PM
cstempert's Avatar
cstempert
Novafreak
If your willing to modify the mount and cross members anything will fit
If your looking for quickest easiest way
Option 1 is 3-spd HD option 2 is the Synchromesh
Any other options going to require crossmember mods, clutch linkage mods, adapting or fabricating and most likely cost as much as a good rebuilt one of the above
Old 12-04-2014, 09:09 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
In addition to the two commonly cited options, the 3 speed heavy duty, and the synchromesh T98 there is another option that doesn't require you to cut your cross member. The light duty three speed was optional on earlier 3/4 and 1 ton Ford trucks and will bolt into an F-2 or F-3. It will not have the transmission mounted hand brake used by late 51 and 52 trucks. This is the same transmission as the popular 39 Ford three speed, but uses a different rear mount.
Old 12-06-2014, 02:51 AM
novafreak69
The truck is a Show quality driver with original patina... The owner wants it more drivable... the spur gear is hard to shift... and I will be changing the rear gear also.... and I would like it to still appear factory undernetah including the trans mounted parking brake...
  #28
Old 12-18-2014, 07:38 AM
novafreak69
I found this this morning... But not trans mounted brake.... and it says T89...
http://www.ebay.com/itm/Borg-Warner-T89B-148-Ford-Passenger-Car-Truck-3-Speed-Trans-Good-Used-/261458578633?pt=Vintage_Car_Truck_Parts_Accessories&hash=item3ce0254cc9&vxp=mtr
  #29
Old 12-18-2014, 08:19 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
The ebay transmission will not help. It looks like an early 60s passenger car transmission.
  #30
Old 01-12-2015, 07:13 PM
Danbear's Avatar
Danbear
Danbear is offline
Swap T9 for T98 Input
Howdy,
I am currently installing a T98 synchro-silent 4 speed in my 1950 F4. Easy install to the engine bell housing once you find a proper 3 inch clutch bell housing. It got real complicated for me when I noticed the rear trans mainshaft bearing retainer (rear motor and trans mount) "foot" was broken off and missing. In process of machining and welding up the lower part of the mount as there seems to be no old T98 trannies around. Yes, the connecting shaft will have to be shortened or the intermediate driveshaft support will have to be moved aft and then the driveshaft would have to be shortened. Pick your machine shop project on that one.
Quick Reply: '51 F3 Synchro Transmission
