Anyone have any experience with Sheet Metal Intakes?
Aluminum or steel?
I'm going to be building my own 3-2V intake and long tube headers for my 300. I'm going with a common/single mounting flange. So I'm going with 14 ga. c.r. steel with 1/2" mounting flange and carb bases. But everyone I talk to about my intake says it's big time overkill.
If you are going steel I think 16 ga. should be fine. If you are worried go 14 gauge.
If it's aluminum you might want to go 14 ga. or maybe even thicker. If I remember right you plan to mount a blower to your intake right? If you are I'd consider all that weight sitting on it. Even with thicker material I'd still add some support brackets along the intake and on the snout of the blower.
I have built a few from round and square tubing, but round flows better as the flow rotates around the perimiter of the tube. Sheet metal would be harder to get equal flow with, but if you install multi-port fuel injectors that won't matter much.
here's a funny one i built to put a 2 Bbl Weber on an old goldwing motorcycle with a flat 4 engine. I lined the inside with fuel-proof Red-Kote tank liner to make sure it was sealed completely
rottenstock
28
10-08-2013 05:46 AM
Lrgfather
11-29-2011 07:24 PM
1951flatheaddave
09-22-2011 03:25 PM
