Ford 6.0L Vaccum Lines - Where do these go?
I have been looking under the hood of my truck recently and noticed three vaccum lines that are not connected.
First a gray line coming from the passenger door area, ran in wire conduit, and comes out in the engine by the engine oil spout.
The second line appears to come up from the front passenger wheel well. It comes up between the battery and alternator.
The third line is capped with a blue cap. It starts from an electrical interface that is above the vaccum pump.
The trucks 4x4 automatic locking switch does not work from the inside. This will be something I will need to work on. Not sure where to start in identifying these, help me out.
If the 4x4 hub is leaking will this drain the vaccum system? I was told when I bought the truck the automatic lock did not work.
Easy (stupid) questions -
What does the heater control valve do? What should I see different when I hook it back up?
https://www.ford-trucks.com/forums/1...alve-leak.html
IllinoisJon
2004 - 2008 F150
12-08-2016 09:25 PM
maevans
37
06-27-2010 12:41 AM
