88 7.3 idi zf5 slave cylinder question
Hey guys,
I got this donor truck for my f350 gas to idi swap and it's also getting a zf5. The only problem with the donor was that I guess the clutch wouldn't disengage to be able to put the transmission in gear while running. It has a new slave and what looks like a new master cylinder but there was the plastic package retainer nub on the end of the slave cylinder shaft in between the fork and the shaft. Is there supposed to be a adjuster nut or something that goes on the end of the shaft? It seems like it should because the shaft is threaded.
The donor truck could have had a firewall flex issue as well. That is a very common issue with these trucks. It can also be difficult to bleed the system.
Both of those could mean the slave and master were fine.
Like Chevy Eater said, the plastic nub is supposed to be there. Not only does it help hold the piston into the slave during install, it also acts as a thin spacer that is required. It also helps to reduce the friction and reduce wear to the shift fork and slave cylinder push rod.
The push rod shouldn't be threaded, a picture would help. Perhaps the previous owner tried to fix one of the aforementioned problems by making an adjustable push rod (or swapping one in from something else).
Trapperpete52
06-05-2014 02:05 PM
hunterguy86
04-09-2007 12:05 PM
