transmission gap
transmission gap
I have a 75 300 engine that had a manual transmission. I removed the transmission and am trying to put in a C6 out of a 78 that had a 300. It seemed it should be an easy swap. I have put the transmission in and I have about a .25 inch gap between the engine block and bell housing that I can't get to close. This set up is in a 65 SWB if that makes a difference.
Happy you found the issue. Thanks for posting it Giving us answers, let's us know the outcome [/QUOTE]
It is amazing how well everything goes back together when you don't have extra pieces in the way. I was able to remove the pilot bearing and everything looks good. I tried to remove the bearing with a trick I saw on YouTube by filling the center hole with wet paper and pounding it out. That did not work. I guess the bearing in the video was not in as many years as mine. Then I went to the local parts store and barrows the proper tools, 6 slides on the slide hammer and I was in business. Thanks for the assist from the forum.
520SC
05-31-2017 10:55 PM
Old Coyote
20
05-27-2013 03:41 PM
Sycostang67
General Automotive Discussion
17
07-31-2009 01:34 AM
