Stock rear bumper position ?
There is one thing I miss, living in north of Sweden and that is the long summer night, and of course all of the snow, that's a whole lot better then all the rain and slush we get down.here.
Just wanted to reconnect to the subject
My truck was equipped with a rear farm bumper when I got it. I would like to get the stock rear looking rear bumper, however I really want a tow hook as I want to be able to pull stuff with it when I am done. I will only be allowed to make an own bracket system for a weight of 1500 kg or 3307 lbs. This is what I had in mind, a bracket system that looks close to the original and that the reinforcement is hidden inside the bumper.
What do you guys think??
DinnerHill SpeedShop: Rear tow hook and bumper bracket design
If I read your plans correctly, the two "C" channels, the flat stock forming the inside brackets, and the drop hitch are welded together to form a box beam. Then you have the actual bumper behind that. I'm not a structural engineer, but it looks pretty good to me.
This is an example of a Class II hitch. For reference, the receiver opening is 1 1/4" x 1 1/4".
That would be what we call a Class II hitch on our side of the pond. It's pretty light duty. (350# tongue weight & 3500# gross trailer weight)
That tow hook is definitely less rigid than the one I am planning.
I might freshen up my solid mechanical skills and see what the numbers tells me.....
Thanks for that picture
I have done my homework and it seems to pass with flying colors
DinnerHill SpeedShop: Strength calculations, Rear tow hitch
on
....Mid 70's Ford stepside bumper. Home made brackets straight out from the frame rails. Plaque is mounted in the trailer hitch receiver. Hitch is also home made. I pull a small fiberglass trailer with it. Tail lights and brackets are stock. Back up lights from a 70 something Honda Civic. (Those goofy little round type cars)... truck is a 47......
Stan. .....
Stan. .....
