2009 6.8 dual exhaust - Ford Truck Enthusiasts Forums
Old 11-22-2014, 08:40 PM
928sport 928sport is offline
928sport is starting off with a positive reputation.
I just removed my Banks system and had a 2 1/2" dual system built. I was sick of the noise between 1600 and 1800 RPM when I was towing, it had a droning sound that was driving me crazy. I called banks and expressed my feeling but you know where that went. So after rethinking the exhaust and looking on the market they all seem to be the same but with a different muffler. So what I did was start out and remove the y pipe just after the converters and run two 2 1/2" pipes into Magnaflow mufflers and then into the banks 3 1/2" tail pipe using a y adapter with dual 2 1/2" inlets and a 3 1/2"outlet. The y that is just after the converters is very restricted, the pipe's are bent a little over half way shut to make that up. The bottom line is the truck makes more power and right off idle it is must better, and the best part is it is very quiet. I would go this way over the big single exhaust if anyone is thinking of adding a exhaust to there truck
1997 F350 7.5L - Banks vs. Flowmaster? IcutMetl 1987 - 1996 F150 & Larger F-Series Trucks 28 03-22-2016 05:05 PM
460 Performance Exhaust Discussion '75HB250 1987 - 1996 F150 & Larger F-Series Trucks 34 03-22-2016 10:15 AM
Can I remove my Banks muffler?? CrispyWafer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 03-23-2015 05:50 PM
3" exhaust question V10man 2004 - 2008 F150 16 03-03-2015 10:27 AM
Dual exhaust on 2009 V10 928sport Modular V10 (6.8l) 11 11-26-2014 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
