Oil from exhaust, recent turbo rebuild????????
I have recently rebuilt my turbo, replaced HPOP lines and a few other things. Truck has been running well. It blew out the HPOP line, prompting this work. I got home tonight and noticed that there was oil spots on the fender of my trailer on the exhaust side. Upon further inspection, the tail pipe appeared to have oil around it and the inside appears wet.
What do I need to be looking at? I still have the crankcase vent hooked into the intake tube. I don't know what could be wrong on the turbo. There is only this small snap ring style seals on the turbo shaft. Is this something that can happen until thing seat in good? I rebuilt the IPR and deleted the EBPV system as well.
Could this be something left over from the. HPOP busting?
Ryan
Ryan
Checked the exhaust pipe at turbo this morning. It was wet with oil. I pulled the inlet tube off to check play and there was 3/16 or so play. I felt like this was too much. Pulled the turbo and there was definitely too much play.
I don't see anything that looks out of whack but I would like to see a diagram of the order in which all the bearings and spacers go on the shaft to ensure I have everything positioned properly. Anyone know where I can get this?
Ryan
Ryan
I did. He is sending me two new brass bearings and new snap seals. Thanks.
I feel like the play is in those bearings. Would spinning the turbo up to quickly before everything is broken in cause this? If so, what kind of break in period is suggested after rebuilds?
Ryan
Ryan
