4wd Won't Engage
do you get either the Hi-Lo or the 4x4 light on the dash ? Do you hear anything when you switch the **** ? Two things happen... one is an electric motor on the transfer case switches HI-LO if needed... second is a vacuum cylinder on the front axle engages the axles to the driveshaft with a pin.
truckmonger1
12-16-2007 07:28 PM
davewatson
01-28-2003 06:10 PM
