body lift for turbo install?
Received 3,102 Likes
on
The problem with body lifting an IDI is that the cab seam actually contacts the head when lifted straight up. That is why all body lift kits say "not for diesel". Body lifts work, but you need to BFH mod the cab to do so. The really tight part is between the firewall and the back of the engine which does not improve with lifting. That said, depending on the turbo, a body lift may be desireable for other clearances. I will probably add a small body lift to my project for intercooler piping clearance and to keep the firewall wiring a little further from the hotside components.
on
oldblue89
05-19-2012 06:29 AM
