How to avoid hole in oil pan...
A while back I had developed an oil leak in the corner of my oil pan and a few weeks later I had to remove and break down the motor (unrelated problem to the leaking oil) so I was then able to look at the inside of the pan. It was obvious the oil pump did this, what I don't know is how to prevent this.
The motor was assembled by an engine builder here in town and he installed a high volume Melling oil pump. I wasn't able to find anything on line that would indicate this is a taller pump than stock (also using the stock oil pan).
The picture is the inside of the pan, looking at what would be the front, driver's side corner of the pan if it was installed on the motor.
Thoughts here? How to prevent this? Is there a specific pump I should be using or a thicker pan gasket (was using cork before)?
Well how "built" is this motor? Running an HV pump on a Ford almost always ends up with the cam eating the distributor gear for lunch, because the stock gear was never meant to take the additional load of a HV oil pump.
So I would just get a Motorcraft or other GOOD (and yes Melling is good) factory-spec pump and run that.
Also... it's hard to tell from your pic because I'm on my phone, but that hole looks like something got punched INTO the pan.
on
Yeah those HV oil pumps don't fit without something getting modified, sometimes a little hammering on the oilpan will do it, sometimes the pump body has to be machined down because the pan isn't even close to contacting the block before hitting the pump. With a fresh rebuild there is really no need for a HV pump,, it just puts more load on the drive shaft and gears, so my suggestion is replace it with a regular volume pump and in your case a new oilpan.
peka
08-26-2015 01:51 PM
76250_4x4
11-06-2011 11:47 AM
NoAZ'68
01-29-2004 12:15 PM
