6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Truck died
Old 11-22-2014, 12:32 PM
jbg machine's Avatar
jbg machine
jbg machine is offline
Truck died
Yesterday, truck ran for 5 seconds then died. Fuel filters changed 4 months ago. Wrench emblem showing on dash. Will any code readers from auto parts stores work to lead me in right direction? I figure it stuck egr valve. Any more ideas
Thanks in advance
Old 11-22-2014, 03:11 PM
RM2738's Avatar
RM2738
RM2738 is offline
Most DTC readers will read most codes. Have the code read and let us know.
Old 11-22-2014, 07:08 PM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
Bet a sensor. or bad fuel.
Old 11-22-2014, 08:37 PM
jbg machine
So will any obd 2 scanner tell me what codes to lead to problems
Old 11-22-2014, 08:47 PM
jbg machine
Will 100$ scanner from harbor freight with a 2008 f450? Has anyone used one on a 6.4 truck?
Old 11-22-2014, 09:23 PM
senix's Avatar
senix
senix is offline
It should read generic emissions codes.
But ford specific ones probably not. Unless it says so.
Old 11-22-2014, 09:26 PM
robcruz1105's Avatar
robcruz1105
robcruz1105 is offline
mine does the same thing but now doesnt even start just cranks and mine reads IDM code and exhaust sensor code so im going to check that tomorrow
Old 11-22-2014, 09:27 PM
senix's Avatar
senix
senix is offline
What are the codes?
Old 11-22-2014, 09:39 PM
jbg machine
I have Dpf delete kit. So would best scanner from auto zone work better than harbor freight one? I have 4 other gas trucks I can use scanner on also. All fords btw
Old 11-22-2014, 09:48 PM
robcruz1105
Originally Posted by senix
What are the codes?
the code that comes out is P1316
Old 11-23-2014, 06:29 AM
senix's Avatar
senix
senix is offline
That is an injector control module detection error.
I really don't think that is a valid code. Clear it and see again.
Old 11-23-2014, 07:33 AM
robcruz1105
i did clear them and it comes out again so im guessing its a loose injector wire connector under the valve cover
Old 11-23-2014, 08:02 AM
senix's Avatar
senix
senix is offline
what are you scanning with?
Old 11-23-2014, 04:44 PM
jbg machine
Bought the scanner from autozone and it says no codes? But wrench light is still on in info center of dash. Any other ideas or why it dosent find codes.
Old 11-23-2014, 04:56 PM
senix's Avatar
senix
senix is offline
Does show a code because it cannot read the ford specific codes.
Wrench indicates a powertrain fault of some kind.
You are going to have to get ford to read it or buy a scanner that will read the specific codes for ford.
Quick Reply: Truck died
