6.0 map psi drops when high boost psi
Hello all so I had a code come on last week it's p0401 low flow to the egr. I have a egr delete and a few other things done to the truck. I started monitoring the map ebp and boost so map and ebp are within one or two most of the time but when I get boost up to 22-27 psi the map will drop to 0 or 1-8 psi. So I'm trying to figure out why this is happening. Any ideas? Thanks in advance!
Yes po401 I think it was. It's for low flow to egr valve. I did do some research and founded that it might be from a leak in the system but from the readings I'm getting from my map you think it's a clogged port to the map sensor?
It could very well be , That threaded nipple down at the Intake gets sooted up , I take the hose off the sensor then use it to help un thread it after I loosen the nipple, while your in there clean up the IAT2 sensor that will be sooted too. also look real close at the Map Hose it's been known to split and leak from there too
Yes the Map sensor is bolted on the heater box via 3 nuts, follow the hose down to the intake. the IAT2 is right behind the upper fuel bowl be carful the clips are brittle and most likely to brake off mine sits in snug so haven't had problems with that if they do. use carb cleaner and a plumbers flux brush.
ware your safety glasses that stuff burns like
Yes the Map sensor is bolted on the heater box via 3 nuts, follow the hose down to the intake. the IAT2 is right behind the upper fuel bowl be carful the clips are brittle and most likely to brake off mine sits in snug so haven't had problems with that if they do. use carb cleaner and a plumbers flux brush. ware your safety glasses that stuff burns like
Ok, continuing on with what has been said here... if you can help me with some similar things.... On my monitor of the engine... when the boost psi goes above about 22-23 psi... it drops out to zero and stays that way until it drops below that.
So, is this somehow related? What should I be looking at in this regard? And is it a problem?
Thank you
Thank you
Thank you
Thank you
If you're using a ScanGauge, the standard boost gauge just does that. There is an "extended" boost XGauge for the 6.0 diesels. If it's another brand of gauge, it may have similar issues.
My '06 has a boost gauge in the instrument panel so I don't monitor it with SG. Flipping through my gauges the other day I came across boost and left it up just to play with. Under high boost (20 something psi) it flipped to low numbers just as you described. Nothing wrong with the truck, just need the extended boost XGauge.
Your MAP, EBP and Baro all should be within 3 psi of each other, look at the readings cold koeo ( key on engine off) Low ( Idleing) Engine warm High ( 2500 rpm ). By the sounds of it you might have a leak in CAC tube or a crack in the Map hose . you may want to take the EBP sensor off and run some weed eater line through the tube just to make sure it's not being restricted. before you try to loosen up that hard line spray some wd or penetrating oil on it first. Does the turbo spool up?
