Several issues with install of Altmans, any input?
This is a great thread as I am wanting to order this set of latches from Mid Fifty....but they are currently out of stock. I plan on welding them....and was planning on cutting the doors like I have seen
CTurner1978 Am I understanding you correctly that I should not make the cut in the door, but rather just weld the plate onto the doors surface?
The internal paws are case hardened. The lock lever is not. I misunderstood the piece you were referring to on the phone.
I ALWAYS butt weld my installations and have yet to have a problem...
Thanks Charlie!
I measured mine and it is overlapping the track nearly 3/16"......... I mean it isn't even close. I could shave 1/16 off of the latch itself if that was my problem.
I don't know what is going on.
DO YOU HAVE ANY PICTURES OF YOURS WITH THE TRACK INSTALLED? THROUGH THE LITTLE WINDOW HOLE WOULD BE NICE!
HUH? This may work fine for the latch manufacturer but it isn't so great for those of us who want a clean/professional job that only a butt weld can provide. I personally find it hard to believe that the thickness of a piece of 16 ga metal is going to impact the operation of this latch. IF IT DOES then this fact should have been presented in the instructions in BOLD letters.
Thanks Charlie!
DISCLAIMER!! You NEVER "shave" ANY amount of the latch itself.
Your lock is overlapping the window channel by 3/16" then something has definitely occurred during installation. You said to me yourself that you find nothing but good things said about our kit. We have sold well over 1000 of these exact kits in the last 8 years and I can honestly say (I take EVERY tech call) I have not dealt with a single issue of the lock not working because it is against the track. With that said, there is a first time for everything and we are willing to work with you to resolve your issue. You have all of my contact information.
Also, you mentioned in an email that you were told by one of our techs that it is ok to butt weld. As I stated, I take every tech call that comes in to our offices and since the first kit we made in 2008, we have had people ask us if it is ok to weld our kits in and our answer has always been the same. You should install the kit per the instructions, and overlap weld the plate on the door.
Ironically at the time I am typing this I got a phone call from a customer that wants to weld in a kit on a 56 F100. I told him to overlap weld it. I also told him about the issue that you are having with the lock and he said if he were to move the latch even a 1/16" closer it would interfere with the lock on one side of his, but the other side he has plenty of room. As many of you know, this is just part of building an old vehicle.
Travis,
I should have said lock lever, didn't mean the actual latch.
I am going to "redesign" the lock lever and have it CNC cut, and then bend so it steps around the track. It will also make installing the lock actuators easier.
I'll send you the CAD files, and you can cut me in for ohhh about 8%, Deal?
HAHA
HAHA
HAHA
Clean install....who would ever think this would be an issue?
I appreciate the manufacturer and their efforts, but my feedback would be to consider a modification that WOULD accommodate a true 'weld in' (butt weld) installation. Surely 1/16th-1/8th of an inch can be created someplace in the design?
HAHA
HAHA
I agree with you that way this installation looks the best is through a butt weld.
This is exactly the way that I was anticipating "welding in", not "welding on" the plate. I like the ideas behind this door latch hardware, and I can appreciate the design effort...and that over 1,000 have been sold...However, IMHO the plate bolted, or welded, on top of the door skin looks closer to Pep Boys than Professional.
Our kit is designed to bolt in. It is not designed to weld in. If a customer wishes to weld our kit in, they may do so. It has been done numerous times by our customers with great results. With that said, the majority of our customers wanted a bolt on kit that required no welding. Also, as you can see, as demonstrated by CharlieLed, several of our customers have butt welded the kit in with no problem. I have even had customers tell me that they have discarded the installation plate and installed the latch inside the door after cutting and drilling their own holes. Each person has their own skill set and their own abilities when it comes to installing anything on their projects. Our product was designed to help the average person install latches in their vehicle without a lot of fabrication skills. The flip side to that is that our customers that do have higher than average skill sets tend to want to do a little more with their installation and they usually do fine.
#28
Another place where you can get in trouble is with the fit of the striker pin into the latch itself. The pin should be perpendicular to the latch, the head of the pin should not bind against the "bear claw latch arm", the pin should be centered in the latch arm when the door is closed, and most importantly the end of the pin should be clear of the inside of the door latch mechanism. If the striker pin is not aligned properly then binding will occur. Here is a pic of what the striker pin should look like when properly aligned...
#29
That was an access hole in case something were to go wrong with the latch. It is covered by the stock interior panel. If the latch were to bind up, you could pop the inside panel off and get to the latch. This was done in the beginning because our first latch kits were a bit of a Frankenstein type setup using another companies latches. After we started manufacturing our own latches, the quality went up, and there was no need for that access hole. Our latch kits now do not have that hole in the plate.
#30
I did order your latches from Mid Fifties yesterday....apparently they had a computer drive fail (saw their post in this forum)...checked on my order and it's not in their system so I will have to call them tomorrow and get my order going again.
Really looking forward to getting a reliable door latch system installed.
If you were to but a number to it, how often do you think butt welding the plate in results in the clearance issues that was originally brought up?
