Cree led lights????
Cree makes the actual led chip, not the entire light.
A side note, most folks selling cheap LED devices GREATLY exaggerate their output. So you need to realize if a tiny single led flashlight size light says 10000 lumens, thats a lie. The current hot chip from Cree is the XM-L2 which puts out about 1050 lumens at 10 watts.
Post a link to what you are looking at though.
Cree makes the actual led chip, not the entire light. A side note, most folks selling cheap LED devices GREATLY exaggerate their output. So you need to realize if a tiny single led flashlight size light says 10000 lumens, thats a lie. The current hot chip from Cree is the XM-L2 which puts out about 1050 lumens at 10 watts. Post a link to what you are looking at though.
Yea those aren't bad looking. I'd definitely use them for at least back up lights.
The other odd thing about the cheap lights is the beam patterns. The above light says it is a spot pattern but it is 30 degrees. That is flood pattern territory. A spot is usually 10 degrees or less.
Yea those aren't bad looking. I'd definitely use them for at least back up lights. The other odd thing about the cheap lights is the beam patterns. The above light says it is a spot pattern but it is 30 degrees. Uhh, thats a flood pattern haha. A spot is usually 10 degrees or less.
I am glad to hear that. I am really leaning to get them now. Only problem i have is do i want to get them or should the wife get them for me for xmas lol
Those may work just fine at night, but I love the photos in virtually every ad of the light not quite shining on a table but still shining on a table, as if that's supposed to illustrate how good the light is...
I have a set of Rigid lights...not sure if they are cree or not, but I can say that something about LED bulbs make reflectors really stand out at night. To keep people from flashing their high-beams at me I have mine aimed so that the "top" of the light pattern hits about 40-50 feet in front of me (so basically pointing down) and just the castoff light will still light up reflectors a good 1/2 mile down the road.
With the cheaper brands I'd worry about the seal (will they remain dry inside after road spray, will the inside of the face fog up with humidity changes, etc.) and the quality of the housing/brackets. If you 'baby' your truck (no washboard roads, etc.) I would hope the internals would last a while, but if you drive on abusive roads, that could become an issue (quality of soldered wire connections, etc.).
It comes down to you betting against the elements really. For that price if you win the bet you've come away with a steal (and you need to report back to us periodically about the quality).
Good luck and keep us posted.
I have a RI bar on my Xterra and I ended up putting a yellow filter on it because of how bad it reflected off of uhh reflective things. Even being off to the side of the road it is crazy how much light gets reflected back.
The yellow tones it down just enough to not blind myself completely.
Those may work just fine at night, but I love the photos in virtually every ad of the light not quite shining on a table but still shining on a table, as if that's supposed to illustrate how good the light is... I have a set of Rigid lights...not sure if they are cree or not, but I can say that something about LED bulbs make reflectors really stand out at night. To keep people from flashing their high-beams at me I have mine aimed so that the "top" of the light pattern hits about 40-50 feet in front of me (so basically pointing down) and just the castoff light will still light up reflectors a good 1/2 mile down the road. With the cheaper brands I'd worry about the seal (will they remain dry inside after road spray, will the inside of the face fog up with humidity changes, etc.) and the quality of the housing/brackets. If you 'baby' your truck (no washboard roads, etc.) I would hope the internals would last a while, but if you drive on abusive roads, that could become an issue (quality of soldered wire connections, etc.). It comes down to you betting against the elements really. For that price if you win the bet you've come away with a steal (and you need to report back to us periodically about the quality). Good luck and keep us posted.
I'll let everyone know how it goes. Probably won't get to install them until Thanksgiving weekend.
Ya i am not expecting more than 1200l max. Thats alot for a light and it was funny u said that because a buddy was showing me a light that puts out 6k off 2 aa batterys and its the size of a maglight haha. But here is the link
Amazon.com: 2 X 18w 1260lm Cree Spot Led Work Light Bar for Off-road SUV Boat 4x4 Jeep Lamp 4wd: Automotive
The link I posted earlier is for a pair.
