Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
clifford is getting there now.
Old 11-21-2014, 06:57 AM
fordman67 fordman67 is online now
fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.
Well those of you that know me know that Clifford is my big red dog of a truck.7800lbs of CC f350 .
As of now I have
Gauges
E-fuel with gsl392 pump
Deleted ebpv and deleted pedestal
Bellowed up pipes(thanks bill)
Dp with 4" home built exhaust(cheap)
Old gold hyper tech (50hp) chip (thk Jason)
6637 based intake built by me
T-500(thanks Glenn)
Flexalite dual 15.5 e- fans
The old guy always made in the 20-22lb boost numbers until the t-500.
My boost now is 29 lbs . therefore I know my old 15* pump was not doing well at all.
I am thinking about getting it on a dyno here locally just to see where I am at.
I feel that it runs pretty well considering 331000 mile original injectors. If it weren't for me being an idiot I would finish hooking the 6.0 ic and call it done. But we can't do that here can we?
What I am trying to say is IMO efuel and good high pressure oil pump are important even with stock injectors if you really want to maximize what you already have . we shall see what the lie detector spits out here soon enough.
Old 11-21-2014, 08:42 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I disagree with one thing, "I would finish hooking the 6.0 ic and call it done". Just like a house, they are never done, LOL. When I get my new tunes, I will also get on a lie detector!
What's next Aaron, injectors?
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The old gray Mare 97 dually cc,modified s366 turbo,stage II's,DI IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
Old 11-21-2014, 09:50 AM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is gaining momentum as a positive member of FTE.
That's a good list Aaron! I need to make one for mine as well. I really wish I could do the HPOP before I head out, but my budget is tapped for the time being. I am stoked to hear its running well and you are happy with it. We are pretty much neck in neck with our list with the exception of the HPOP and electric fans. I will be curious to know how those do when towing. Post some pics dude!!
__________________
Byron
1997 F-350 CCD-PSD, 6637 Intake, 4" Stainless Exhaust, 3" DP, Uppies and E-Fuel by Re-Billd, EDGE CTS, Glow Shift FP/Boost Gauges, John Wood E4OD HD, EBPV Deleted Pedestal, TS Chip, 230k Miles
**Exiss 6-Horse Gooseneck, Front Tack/Sleep Area
**2011 34' Sundance by Heartland TT (10,700#)
Old 11-21-2014, 10:10 AM
Glenn...injectors...well you never know what's down the pipe:-)
Byron.I'll be honest.I wouldn't do injectors until after a good hpop.
After this I'm sold .
Big things are no boost leaks and no exhaust leaks!!! (Both of which you have handled)
And adequate fuel.I had a tight stock system with new pump and shimmed regulator and pressure would drop from 70 down to 30 on a hard pull.
From my experiences these things need done just for a mild setup if you want to maximize the stock hardware.
Yea I need to hook up the ic...just not wanting to do it twice :-/
Old 11-21-2014, 12:46 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is online now
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Sounds like you got the "Big Dog" woke up and running well! I'm hoping to be traveling a similar path myself soon, but you know how that goes....
I'm curious as well to hear what you're putting to the ground with those mods.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
Old 11-21-2014, 01:17 PM
Trying to get the boss to agree to let black friday be dyno friday....I called and they are open and I can get an apt....
I sure feel you nate....two and a half years to get to this point.family is good....just slows down project progress.
Old 11-21-2014, 01:38 PM
Yeah, family just changes your priorities, that's all.
__________________
Old 11-21-2014, 01:50 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Do a hear a high pitched whine in your future!!!???? Run Clifford run! Lol
__________________
Todd
96 F350 4x4 PSD, CCLB, E40D -> ZF5, 4.10ls, Riffraff 6637, 3" DP to 4" straight pipe, SD 17*, Autometer Phantoms, BTS tunes, 180/80 stage II's, DIY/Rebilld E Fuel, Aeroforce Scan Gauge
On The Shelf - Intercooler/pipes 350-380HP on the Travis Dyno
Old 11-21-2014, 03:27 PM
Never know what exactly the future MIGHT hold...
Old 11-21-2014, 06:11 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is online now
MOOSE_MACHINE is gaining momentum as a positive member of FTE.MOOSE_MACHINE is gaining momentum as a positive member of FTE.
Devilish grin hehehe
__________________
Sometimes your the windshield, sometimes your the bug
1997 F-350 xlt cclb PSD 4x4 zf5, 160/80's, custom tunes, T500, DIY e-fuel, 6.0 i/c, 38R, 3" plenums, gauges, 4" turbo back exhaust, diy bellows, south bend clutch
1992 F-250 2wd eclb 5.8 farm truck
1989 F-350 4x4 7.3 c6 auto retiread
Nick
Old 11-21-2014, 07:34 PM
^you got that right^
Old 11-21-2014, 09:41 PM
martin72's Avatar
martin72 martin72 is offline
martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.
Glad to here Clifford is coming along, your making me jealous because I can't get time to work on the Mistress.
__________________
Kevin
Mistress 1994 f350 CCLB DRW 7.3 Power stroke ZF5 4x4,TS 6 Position Chip, 6637 filter,Rancho RS 5000 shocks,
5" diamond eye exhaust
Old 11-22-2014, 08:13 AM
Sometimes you just have to put stuff to the side lol
Old 11-22-2014, 09:56 AM
Aaron I am really stoked for you that Clifford is running well! I know the feeling. Ruby has been so good after getting the oil pressure switch for my E-Fuel figured out. When I do the injectors, I am doing the HPOP at the same time.
So, far my pressure only drops about 10 pounds on a hard pull, but I am guessing I will really see it when I am pulling a grade with the trailer. I'll have a thread started for when we move in a couple of weeks. Stay tuned!
__________________
Byron
Old 11-22-2014, 12:55 PM
Yours drops? Have you still got the 2mic output filter?
Similar Threads
Clifford Intake / Weber 38 Carburetor KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 07-30-2014 05:58 PM
my winter list fordman67 1994.5 - 1997 7.3L Power Stroke Diesel 391 06-21-2014 09:59 PM
BIG RED's build thread ReBilld 1994.5 - 1997 7.3L Power Stroke Diesel 1680 05-02-2014 06:11 AM
Building E-fuel ProjectDually Kansas Chapter 4 03-17-2014 09:07 PM
E-Fuel Mod and Bigger Rear Tank tarheel007 1994.5 - 1997 7.3L Power Stroke Diesel 31 12-05-2013 08:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
