Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Old 11-20-2014, 11:39 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
technical thoughts about wmo and timing, surging, and drivability concerns
I've been running wmo for quite some time now, and have some thoughts bouncing around my head about it.
1) I've heard multiple guys around here acknowledge the surging that seems to just happen for us oil burners. I've been analyzing it every time I drive and think I have a decent understanding of what's actually happening. I used to think I was suffering from fuel starvation, but now I don't think that's the case most of the time.
2) my current theory is that all this surging and variations in performance is caused by improper timing control. I notice what seems to be the timing going far advanced, making excessive clatter and more power than normal. I used to blame this on air intrusion, but now I think otherwise. Other moments on the road I seem to lose power but not completely. I believe this is the timing going retarded. In these events I have no clatter at all, it sounds like a gas motor, and I can maintain speed but not up hills, it's gutless at these times.
And it goes back and forth between these two conditions quickly, too quickly for it to be fuel starvation or air intrusion.
The prevalence of this issue directly correlates to the percentage of used oil in my fuel, with it performing normally on pump fuel.
So all that said, I'm thinking that the problem is clearly that the timing controls inside the injection pump are responding randomly when the fuel is too thick.
Does anyone have any input on my theories?
Obviously the simple response is to adjust my fuel mix to a level that works right, which I'm running around 75% oil in one tank and mostly pump fuel in the other.
I have a ferett timing meter and set it properly when I installed the pump, so I know my base settings are correct.
Old 11-21-2014, 07:17 PM
MNBen's Avatar
MNBen MNBen is offline
MNBen is starting off with a positive reputation.
I have not experienced this in my '02 F250. My mix is 2/3 wmo 1/3 d2.
What are you driving.
Old 11-23-2014, 03:31 PM
I'm running an 87 e350 with a 6.9, so a whole different fuel system than your 02 has.
Old 11-25-2014, 11:55 AM
ProjectDually's Avatar
ProjectDually ProjectDually is offline
ProjectDually has a good reputation on FTE.ProjectDually has a good reputation on FTE.ProjectDually has a good reputation on FTE.
Pandemic Vapor
I have no personal experience yet, as I am still juggling with converting my 94. 7.3 into electric fuel. I have also been reading up on converting my second tank into being able to handle straight bio once I do.
But, my buddy has used WMO before, he said his power issues were related to fuel temps pre-injector and the size of the pre and post fuel filters getting clogged up. Do you use a heated fuel filter element? Also, are your injectors rated to run bio without issues?
__________________
John
VetNet
1994.5 F350: CCLB PSD - Project truck.
1997 Audi A4 2.8QM 12V-V6- Daily driver
Similar Threads
WMO ideas? 10thMountainMechanic Bio-diesel, Propane & Alternative Diesel Engine Fuels 28 09-08-2014 06:27 PM
7.3 idi is broken rjrandy96 Bio-diesel, Propane & Alternative Diesel Engine Fuels 6 07-27-2014 09:39 PM
randomly switching between high and low power, trying to figure this out joshofalltrades Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 45 11-22-2012 02:42 AM
HELP! WMO Excessive smoke! 7.3 IDI Allen72289 Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 03-01-2011 03:21 PM
An idea for filtering WMO... BSmitty Bio-diesel, Propane & Alternative Diesel Engine Fuels 17 08-02-2006 04:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
