How I know I have a 390
First thank to all for making this way to help orders.
I am new in this is my frist time! I am from Costa Rica but I live her in USA now! I got a f250 from a friend, he tell me the truck has a 390 but he wasn't sure! I want to know, if it is I do want to rebuild it so here are some numbers I fun it on the intake# 8H28 : C9AE 9425-B
Here on the block 352 in the right side "I think" 38 DIF and W 8H20
Muchas gracias! Puravida
Tico, as you found, the only way to tell is measure the stroke or check the crank numbers.
This will tell you what the vehicle was built with, NOT what is in it right now
Thx krewat
puravida okay thank you so much but I can measure the Stroke because the engine turn and get stuck and so I can't move it anymore longer so I can get the right measurements I pull it out the oil pan I check the bearings they are okay then I check the engine in here are the number I found out.
In the right side on the block
This Under oil pump
Ok and this want it tell me is a 360 so it is
And what this means X 48
Again thank you so much now what I do recycle the engine or worth saving in block
This Under oil pump
Thx Krewat
I can not check the stroke because the engine does not reach all the way around stick in a point and I can't go more, I'm don't know where or what causes it, and the crank numbers are 2T and 23 does all I can see, when I try to turn it sticks to the right or left. Gracias amigo
look at your vin number and if its 4th letter is a Y then the truck came with a 360 if its an H it came with a 390 but thats only if it is the original motor to the truck..... casting codes don't mean anything on a ford motor thats a cheby thing the only thing it refers to is like the C8AE and C9AE mean 1968 and 1969 respectively i hope this helps you a little.... and if you pour some Marvel Mystery oil or another type of penetrating lube down the spark plug holes it can help free up you engine sometimes...... more information.... the 360 has a stroke of 3.5" and the 390 is 3.78" both motors share the same bore of 4.05" they are the exact same block and one of the common things you learn is that if you use the 390 rods and crank with a 360 piston it raises your compression ratio from 8 to 9-9.5 and since your heads are pre 72 they tend to be better compression heads but they have soft valve seats which can wear/wash out with the gas they make us use these days since these motors were designed to run off of leaded fuel..... good luck tico if you have any more questions feel free to ask
Thank you for your help
Thank you so much! Yes I do have a 360 thank you to all off you! Thank you smokenchoken for your help with the oil it works and now I do have a free engine yay....,
PIDI
01-06-2012 08:52 PM
flyingtexan
11-21-2007 08:09 AM
b17goinmyway
19
09-20-2007 09:37 AM
grumpy1
09-06-2003 08:57 PM
72 F-100 Ranger XLT
01-26-2003 11:18 AM
