60psi boost gauge?
What size injectors you guys are running, what turbos, if you went to a second turbo, had to do headgaskets. I have done a fuel pump upgrade, 1.5 injectors, dp tuner, and the mandatory bolt ons. I want to do a T4 and go from there. Do I have enough injector to run a T4, what boost could I get from a smaller turbo, will I lift the heads?
Heads don't lift easily on a 7.3L, but I don't know those limits. The valve springs are the real worry. If one opens from excessive pressure and the piston comes to the top with it open - "open" is exactly what can happen: You can open a window on the block. I don't know if the "1.5s" (160/30 or /80?) can get you there, no matter what turbo. I have 160/100s and a GTP38R without sooting problems. If I tweaked it and ran my race tune, I might sneak up on 40 PSI boost - but I don't want the expense of pushing the truck that hard.
Gaugepro is our resident expert on learning the limits of the truck and what hardware puts you on the guardrail - or over it.
wycowboy
13
04-07-2005 11:22 PM
