Aftermarket Plenums
Aftermarket Plenums
I'm comparing intake plenum manifolds from both riffraff and irate.
Riffraff come in at $300
Riffraff Diesel Billet Intake Manifold Plenums - Riffraff Diesel Performance
Irate at $225
Buy Online | Irate Diesel Performance LLC
Any reason (from a product comparison's perspective) why I would choose spend an extra $75 for riffraff's product over Irate's? (All other company influences aside...)
Irate at $225
It really comes down to quality. You can see it on the different links, but you can really notice it when they are in your hand. One costs about $75 to make and has worse flow/ more turbulence than stock. The other is a high-end engineered product that flows something like 19% better than stock, from what I remember when I bought mine.
I noticed that Beans has even stopped selling their billet plenums and are now selling Riffraff's, so that must say something as well.
http://bdpshop.com/riffraff-diesel-b...d-plenums.html
I can't find a reason to justify spending hundreds of dollars for something that does nothing.......
If by nothing you mean you have a stock truck and aren't trying to get performance then maybe, except the oring seal is still a better design.
If you are trying to flow more then, aftermarket plenums are needed. But saying they do nothing is a ridiculous remark considering airflow is integral to performance at higher levels. Less restriction, more flow, better efficiency.
Correct, except Riffraffs isn't flat on the underside, it's contoured for flow. They posted visual flow pictures for velocity and restriction a couple years ago on here. Look them up, or you could pony up and get a flow bench I guess. Why condemn something you aren't able to disprove. I think I will side with math instead of your hunch.
And just to note, yes I have aftermarket plenums on my truck. Don't purchase them with the expectation of them to be any sort of performance enhancer.
Because nothing on the plenum itself changes what's underneath it.
I'm not knocking the product. It's nice. Just expect precisely zero improvements in performance from an otherwise perfectly functional stock plenum setup. Doesn't matter if it's a bone stock truck, or a 700hp beast.
Now if you've pinched the stocker and it no longer holds a seal because it's bent (which is quite easy to do), then yes fixing an existing boost leak with aftermarket plenums will bring back lost performance, efficiency, etc.
For me, my truck being an E99 these new Riffraff plenums are larger at the mouth my stock opening are (I believe) 2.5 inches where the new ones are 3". So I'm hoping to gain some better performance but that being said I do need to change the turbo up pipes and spider for it all to come together.
Sorry for not being much advice on the exact subject.
Hey Pocket, good to hear from you. The improvements are as you listed, they don't crush, warp or crack, and they don't blow the RTV out the bottom at higher boost like happened on my stockers.
Performance gained is in the flow, I will post it if I can find it again, but there is a flow map that shows the gain in the neck. I measured mine as well when I got them and the inside diameter was larger than stock. I think Riffraff posted something like 19% better flow over stock.
