Building The Beast (phase 2)
#93
#94
I did an inspection on it just now. This is my report: no evidence of leaks from the heater core side of the connections. Still seem to have some around the block side. I'm not 100% sure if this is because the hose was not tight enough, or the fitting is jacked up. The later is NOT good. Secondly, I have pictures from the rear of the engine.
This is a picture of the puddle from the driver side. I tried to include the radius arm for location.
This was taken under the truck. It shows the coolant seeping from the bell housing.
I'm running out of ideas as to why these leaks are there and how to remedy them. It is almost looking like freeze plugs, but I run a 50/50 mix coolant.
I did double check the heads, and no evidence of leaks from them. Suggestions on what and how to check? I'm about ready to take it in for pressure testing. I want exhaust first.
#95
Looks like coolant coming down the back of the engine, down the bell housing, and dropping off of the clutch cover. There are no coolant plugs in the back of the engine nor heads, so it looks like all that can be is a head gasket leak. Sorry. Hope I'm wrong, but....
Get a mirror and light and see if you can find a track from the back of the head/block join down. Or, go to the auto parts store and see if they have a dye to put in the coolant to find the leak via a black light.
#96
#99
#101
[update]: I rechecked with a mirror and light again. I saw what appeared to be a trail from the EXACT SAME SPOT as before! I don't like what this implies. One of three possibilities arise: the PO did a head gasket job and botched it by marring the back of the head, or my second set of head gaskets have failed after about 10 miles, or the head cracked on install. It's a small leak, no more that 1/4 of discolored paint. Why is this crap happening to me?
#103
#104
Wheels opinion
So here are the wheels I am looking at for the Beast:
KMC XD775 Rockstar wheels in machined and black
After looking around a lot, these are about the only five spoke wheels I can find for the F250 bolt circle. Do you guys think these will be appropriate for a Bullit tribute truck?
#105
I'm not sure I do think they fit with the theme. McQueen's Mustang had what look to be dark centered Halibrands. But those aren't available for your bolt pattern?
My problem is that I can't visualize the wheels you mentioned on your truck. Can you find them on a site that lets you select a vehicle to put them on?
