Building The Beast (phase 2)
#31
#32
#35
#36
#37
Slots and holes increase surface area, and = more area able to shed heat.
Slots and holes in the friction surface also reduce swept area, and also means less mass to absorb heat.
Larger diameter rotors will give you more swept area, more torque arm, and if the manufacturer knows what they are doing, will be made light enough so they do not significantly increase gyroscopic inertia. (which you both have to accelerate and decelerate)
There is a big difference between an F1 car, a one time panic stop and riding the brakes down a mountain with an overloaded trailer.
In a perfect world, beryllium would be plentiful and non-toxic.
#38
Drilled rotors are just a recipe for fatigue cracking, I wouldn't touch them.
Slotted rotors are however very good at breaking the boundary gas layer between the hot pads and disk, well worth using.
Don't forget the brake lines themselves are a big factor in pedal feel and stopping power, replace the flex lines with proper braided units.
And super dot4 fluid too
#39
#40
I like ceramics for everything but work trucks. Anything that's going to tow, haul, work, etc gets semi-metalics. They deal with the heat better than ceramics do.
Bendix and Wagner are great brands. Spend some money on good pads, $30-60. The only thing that ever get the $10 pads is something I'm selling. They'll be doing brakes in 10k miles...
#41
Recently did a brake job on my moms car. I got wholesale closeout Raybestos PG pads/shoes. Two wheel cylinders. $35 to the door gotta love wholesale closeouts. $10 of that was shipping. The place I bought it from, several people won't like though.
After looking around at the Les Schwab website, it appears they use Raybestos PG plus pads and shoes. If that's what they used in 2005 when my brake job was done, then that's what I'll get next time.
#42
As an aside, and an update, I'm sitting at the muffler shop today. Good news/bad news kinda day. Good first: I have my quote for the exhaust. Bad news: the MC filter I installed after swapping the head bolts blew its seal, and now I have to foot the bill for an oil change. Also, the old positive cable is bubbling, so that's on the near-future list. Any ideas on why other than corrosion that this is happening?
#45
