Early 50 fenders on a 52 bed
I managed to aquire a set of early 50 rear fenders... I'm buying a bed kit that is intended and pre drilled for the 51-52 fenders ..
I will need to work the 50 fenders ... But will they bolt up or can they be made to work on the 52 bolt patern off the bed.... I haven't found any information on the differences
As far as I know, the bolt pattern is basically the same. Your real problem will be the indention for the rectangular raised panel on the 48-50 beds. You'll have to flatten it out so that it fits the 51-52 bed, and that isn't easy to do. I would recommend you keep looking for the correct fenders to match your new bed.
Let me give you my take on that. When most of us join this forum, we really don't care about patchwork things like a 51-52 bed on a 48-50 truck, big truck fenders on an F-1, etc. Quite frankly, we don't even notice them. BUT, if you become a regular daily visitor to this forum, and you end up looking at thousands of truck pictures each year, you will become an expert in spotting the inconsistencies. There's nothing wrong with the changes, nothing at all. But as you become a student of these trucks and learn to spot things, it will probably bug you to death that you have the wrong bed in the future. My point is you might regret the change later. But, like we always say, it's your truck. Do what you want to with it.
That would honestly probably be easier than trying to even out the indention on the original fender and reforming that tab where the bolts go through.
This might be your best option but shipping is about 100-200 bucks depending on where they are going.
I have done business with 51Panelman on here for front fenders and running boards, he seems to have all of the parts you can ever want.
Im not sure where you are located but there is a guy in Ohio who has a few set of fenders for an "ok" price but he wont ship them.
In my opinion, something that is cheap will always end up costing a lot more in the end. You may save a few hundred $$ now by buying 48-50 rear fenders, but the labor and cost to turn them into 51-52 rear fenders will far outweigh the cost if you would have bought the correct fenders from the start.
I have two pairs of 51-52 F1 rear fenders.
Rotted at running boards.
Pretty much solid.
Shipping is only about $100 to Colorado.
Pretty much solid.
As far as the bed and fenders I'll look into the tailgate issue... I'm still not 100% on the direction I'll go... But I'm leaning toward a year correct bed I guess time will tell ... Allthough I'm not really concerned with having a totally correct ride as I'm starting with a 52 f3 flatbed and I'm building it as a nice driver Hotrod for my girl
Time out, everyone. We've been assuming F1 stuff here talking about the differences in early and late fenders. If we're working on an F3, the rear fenders are the same on F2/3's from 48-52, which are totally different from either of the F1 fenders. And the larger beds on the heavier trucks are not reproduced.
