Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 11-18-2014, 08:30 PM
therigwelder therigwelder is offline
therigwelder is starting off with a positive reputation.
hard start problem
Now that I have the pinhole in my block sealed I can concentrate on my original problem hard start.the glow plugs and GPR seem to be working fine.It seems like I am losing the "prime". Almost like the bowl has to refill itself before it will start
__________________
95 f-350 powerstroke
97 f-150
Old 11-18-2014, 09:25 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.
Have you checked each glow plug to make sure they are good, and checked the relay with a volt meter?
__________________
Bill
'95 F350 CCLB 4x4 dually,ZF 5spd,4.10,Rosewood Stage 2s,T500,S366,IC,Tony Wildman tunes,e-fuel,6637,CCV mod,3.5" DP,Diamond Eye 5" exhaust,Valair clutch,IH water pump,Scangauge,GlowShift gauges
'92 F350 CCLB 4x4,ZF 5spd,4.10,460 gas to PSD conversion project truck
Old 11-19-2014, 12:53 AM
fordman67 fordman67 is offline
fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.
Pull the high pressure oil pump plug and check the level after sitting long enough to have the problem. That can happen though not normally or often .
Old 11-19-2014, 07:30 AM
The GPR is brand new.I have not checked each glow plug. The wait to start light lasts about 25- 40 seconds.The truck will attempt to start almost everytime I crank it but it won't catch and run the first few times.Is it possible to have a back flow of fuel when sitting overnight through a weak fuel pump
Old 11-19-2014, 07:40 AM
After the light goes out keep waiting 30 seconds.then hit it.the glow plugs will be on for up to two minutes.the wait to start light is just a reminder.it can take more warming in very cold weather.
Old 11-19-2014, 12:30 PM
madpogue madpogue is online now
madpogue has a very good reputation on FTE.madpogue has a very good reputation on FTE.madpogue has a very good reputation on FTE.madpogue has a very good reputation on FTE.
The fuel pump doesn't hold fuel. The fuel bowl does. If the bowl is not remaining full, you have a leak.
As fordman67 suggested above, what can "leak down" while parked is the injection oil (HPO). Remove the reservoir top plug next time you park it, and note the level. Replace the plug, then after it's been parked a while, check it again. If it's gone down, there's your problem. HP oil is draining back into the pan while parked.
Old 11-19-2014, 01:51 PM
Reservoir is full.I tried to start it this morning and it would bump like it wants to start but after about 15 mins of that I sprayed some "liquid crack" in it and she fired up. (Yes I know better)it seems to run okay but every once in a while it will stumble or just out the blue die but will start back up.i need to make this truck dependable right now I am scared to drive it anywhere.
Is there a way to test wiring harness for ohms to the glow plugs or do the covers have to come off?
Old 11-19-2014, 07:09 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
You can ohm the gp's through the harness plugs on each head in the valley. 2 on each side. The outside pins in each plug are glow plugs. Test to battery ground. They should ohm out at about 1 ohm each. The middle pin is a common ground. The other two are injector pins. If you want to test them they should ohm at about 3.2 each, tested through the common ground. Sounds like you have some dead gp's.
__________________
Darin 99 ranger 76F250 66 fairlane
"TheBeast"1997F2504x4dually4.10's,160k,140VIDM,HPX ,4-5"dp, S366 turbo w/wicked wheel, 6637, elec. fuel,rosewood stage ones,php hydra,arp studs, comp springs, smith brothers push rods, honeybadgerjr hpop,riffraff res,melling lpop,180 tstat,6.0 fan and IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and billet converter, upgraded trans, F550 leaf springs,SD dual tensioner upgrade, cold ac mod
Old 11-19-2014, 07:17 PM
wow thanks I still might have to pull the vc's. maybe I will get lucky and everything will ohm out ok
__________________
97 f-150
Old 11-19-2014, 07:24 PM
ReBilld's Avatar
I agree with Darin. I also think you have some bad glow plugs. Another quick way to test the glow plugs is using a 12v test light. Clip the ground wire of the test light to the POS terminal on the battery. Unplug the the valve cover harness plugs and touch the tip of the test light to each outside pin down in the valve cover gasket. If it lights up the GP is good, if it doesn't light up, the GP is bad.
__________________
Bill
Old 11-21-2014, 08:40 AM
I am going to check the gp's and injectors this weekend.If I have to remove the valve covers to replace parts are there any other mods or improvements I need to make?
Old 11-21-2014, 09:27 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to all
Rebuild the injectors.
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop
Old 11-21-2014, 09:34 AM
Quote:
What's the cost on 8 injectors?where do I get the rebuild kits for injectors? I don't want to pull the VC's again for a long time.
Old 11-21-2014, 09:47 AM
Rosewood Diesel Shop
__________________
Old 11-21-2014, 10:36 AM
Yeah I just called rosewood they stopped selling rebuild kits for 7.3 strokers 4 years ago.rebuilt injectors are 150 each.1200 plus shipping and applicable tax.wow don't think I can't afford that right now.does anyone else sell rebuild kits?
Similar Threads
Hard start after sitting mustangmatt 1987 - 1996 F150 & Larger F-Series Trucks 1 10-06-2011 03:57 PM
hard starting slifer Ranger & B-Series 8 01-18-2007 08:13 AM
Hard starting cowboy51 1994.5 - 1997 7.3L Power Stroke Diesel 1 11-08-2006 01:07 PM
downhill parking hard to restart Pigeon Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-16-2006 06:57 PM
1994 Explorer Hot Hard Start PAJ Explorer, Sport Trac, Mountaineer & Aviator 1 07-12-2001 11:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
