Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 11-18-2014, 06:51 PM
rneithammer rneithammer is offline
rneithammer is starting off with a positive reputation.
1951 F1 V8 - Heater Core
My heater core is shot. The best option seems to be a place in California that will rebuild my heater core.
Are there any other options?
Old 11-18-2014, 06:56 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider is gaining momentum as a positive member of FTE.firstrider is gaining momentum as a positive member of FTE.
Is it a co. called Brass Works ?
__________________
1994 Dodge Ram Van ( the work truck ) ,1993 Dakota w/ 44k mi.,1952 F-1 the 1ST-RIDE ,23 T-Roadster w/ 426 wedge bored to 440 (85 % done ) ,1952 F-1 stock (under const) "Those of you who think you know it all are really annoying to those of us who do " Mark Donahue or Roger Penske Indy '71
Old 11-18-2014, 07:00 PM
Not sure...my repair shop found them. I'll find out.
Old 11-18-2014, 07:05 PM
JWC 3's Avatar
JWC 3 JWC 3 is online now
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
I had a local radiator shop rebuild the heater cores in an old Mercedes back in the 90's . Ask around your area . Worth a try .
__________________
78 F100 ,Daily driver . Life will test you . Never give up ....
Old 11-18-2014, 07:53 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 is a splendid one to beholdTedster9 is a splendid one to beholdTedster9 is a splendid one to beholdTedster9 is a splendid one to beholdTedster9 is a splendid one to beholdTedster9 is a splendid one to beholdTedster9 is a splendid one to behold
Check the catalogs like Summit or whoever that offer a bunch of them. So long as it halfway fits and the hoses hook up OK, that ought to work fine.
__________________
Keep 'er between the ditches.
1964 F-100 292 V8
2009 XLT Ranger 4.0 V6
Old 11-18-2014, 08:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
I'd get it rebuilt. If the hose connections aren't identical, it means new holes in the firewall. If it doesn't fit the heater frame perfectly, the fan just sucks cold air around the core. Too thick, the fan might hit it. Why mess with it?
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
“It’s really hard to make predictions, especially about the future.” -- Yogi Berra
Old 11-18-2014, 08:19 PM
firstrider's Avatar
This replacement heater core subject is not as easy as it sounds .The core must be exactly 7 7/8 x 7 3/4 x 2 1/2 " thick or it will not fit in the heat disappation pan in the back of the heater .The pan sits on 4 rubber insulators . .The center section of the heater which contains the heat regulator door gets squeezed on the front side of the core thus the importance of the correct thickness .With the 2 1/2 " thick core one still needs to squeeze it together during assembly with padded clamps . They go together tight .A lot of parts are inside one of these heaters & clearance is an issue . Have a box full of good cores and more boxes full of dead cores . Keep them around for good tank s& tubes .
meithammer , have they given you a price on a replacement core ?
Maybe I could get a volume discount .
__________________
Old 11-18-2014, 08:26 PM
firstrider's Avatar
Do you have a standard FORD block letter box type heater , a Magic Air heater or a FORD script fresh air heater ?
__________________
Old 11-19-2014, 01:09 PM
Universal Carnegie Manufacturing
Old 11-19-2014, 02:02 PM
ALBUQ F-1's Avatar
postin' fool
Firstrider's point is very important; if you've just asked for a replacement coil for a '51 Ford truck heater, no telling which one they are quoting. Mine turned out to be from a car, not a truck, and many heaters were dealer-installed using what was in hand, and still others were added by the owners using Monkey Wards or Sears pieces. A picture would clarify.
__________________
Ross
Old 11-19-2014, 02:04 PM
The plan is to send my old core to this manufacturer, who will re-core using the old headers, matching everything up as closely as possible.
Similar Threads
High Output Heater Option Drac 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-20-2011 11:15 PM
Heater core replacement procedure 1992 F250 boothtec 1987 - 1996 F150 & Larger F-Series Trucks 1 12-05-2008 04:59 PM
heater core 68FE390 1967 - 1972 F-100 & Larger F-Series Trucks 14 10-19-2007 07:52 PM
heater core 62Cole 1961 - 1966 F-100 & Larger F-Series Trucks 4 01-01-2007 10:43 AM
heater hose routing fordflaresides 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-12-2005 07:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
