Hot EX going to play in snow!
#46
#47
BUT You have to stay on the road. No If and or Buts about that one.
And no bumper cars unless your in a safe place talking photos.
Sean
#49
Just out of curiousity, you mentioned the resort said that they tow multiple diesels off the mountain each winter. Did they mention why? Granted the person on the phone probably didn't know. I am assuming its because they wouldn't start. Either gelled fuel, dead batteries from cranking, etc.
If they gave you any indication, those would be things to make sure you have covered. However, I think you've gotten a lot of good info here and should be just fine.
#50
BTW Yes, they said gelled fuel and for those that stay at the resort that can't plug in it's been a problem. In my case, I purchased the anti gel performance treatment and since I rented a cabin I will have access to power from inside the garage. They told me twice "don't forget an extension cord"... I would think if it's just batteries they would be able to jump with another truck.
#51
This is my first diesel and I am still getting used to it so I don't know if this info is accurate or not, so please confirm it with others before relying on it. However, I will say a good friend who is a heavy diesel mechanic, owns a trucking buisness and daily drives a f350 dually with a 7.3 told me this info:
If your fuel is going to gel up, it will most likely happen at the fuel filters. He told me that he always keeps a spare filter and diesel at home. If your fuel gels up, replacing the filter and dumping some diesel into the filter housing should be enough to get you started. Its unlikely the entire tank will gel up.
Again, maybe someone else can confirm that this is accurate information for our trucks too.
#52
#53
#54
#58
#59
Also found this locally...
Attachment 109960
Attachment 109960
warms then just a bit. And being cold they will show any problems
that have not been showing in the nice warm of Florida.
AND he did ask what would be some good things to take.
Sean
#60
Ever used Rain X before? That stuff leaves that nasty Rain X film on the glass.
Yes, The things is by putting a little current into the batteries it
Sean
Sean
I'm well aware of what a battery charger does.
If his batteries are bad enough that it won't crank the truck with it plugged in, the truck isn't going to start in Florida either.
Taking a battery tender is silly. Good batteries will start the truck just fine.
