Hot EX going to play in snow!
Old 11-19-2014, 09:03 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Originally Posted by Skip1970
must be one of them NEW houses. they dont fit big vehicles like they houses of 15 or more years ago.
Built in 1970 full remodel do to a major garage fire in 2001.
I don't know if it would of fit in the old one but maybe it would of.
But I think your right and they may of lowered the high of the
opening in the front for the door.
Sean
  #32
Old 11-19-2014, 09:29 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Sean
its funny most people i know that bought a new house, the garage is to short and to low to fit a big suv or crew cab truck into. i think they are making them all for kia's now. i hate how the new houses around here put the garage under the living rooms usually. i like a detached garage best so if it burns down the house survives.
  #33
Old 11-19-2014, 09:30 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
I will add a few things here.
1. What kind of tires do you have cause this dirt and snowing road might be a bit much for old bald heat work Dlorida tires.
2. Get a few bottles of Diesel Kleen and add to every tank on the way up there, you will be fine on fuel.
3. That 15w40 oil is going to be a problem for cold starts, even if you use the block heater, it doesn't heat the oil. I would suggest either an oil pan heater and the block heater be at the ready depending on the temp,s, or change to 5w40 synthetic for the cold starts. Cold oil will cause all manner of issues on initial startup, it can be done but do you want to pop something in the high pressure oil out at the cabin.
4. You are changing your oil awfully early at 3000, fuel filters at 6000. Why not 5000 and 10,000? No problem with synthetic oil.
  #34
Old 11-19-2014, 10:00 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
1) 35's Nitto Terra, very far from bald they have less than 7k miles.
2) ordered 6 bottles today
3) I'm changing it before I leave
4) same reason I wash my ex 3 times per week because I'm **** and have a little bit of money so why not lol
  #35
Old 11-19-2014, 10:25 PM
LivingLarge
Bought an ice scraper with brush that extends like 50 inches online... I can just picture the shipping department, Fort Lauderdale WTH!
  #36
Old 11-19-2014, 11:16 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
You could also use a frost blanket in place of the scraper.
Now as far as a little bit of money. You can send some to me.
I will send you a Thank You card. Just PM me for my mailing address.
Sean
  #37
Old 11-19-2014, 11:30 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
LivingLarge,
If you have a nice 12G extension cord that would be the
best one to plug the heater into the wall if you have to use one at all.
Sorry for the major
To give you an idea of the scope of the fire.
The interior made it out ok. The wall between the garage and the
house was a fire wall and the door had a decent fire rating.
We got a lot of smoke from the stuff that was burning and that came
in from the heat ducts. Once the fire department got the big truck
with the boom mounted nozzle there it was out fast. The other problem
was water pressure so the first trucks had a hard time with it and they
almost lot it because of that. I forget the truck count but more than half
were water tankers. One block of fire equipment or about 8 trucks I think.
That fire was first part of October after 9/11.
Took about 4 1/2 months to rebuild it all. That
is after all the permit BS and the time that took.
Sean
  #38
Old 11-20-2014, 08:10 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
If the power is already there and he is not
going to be charged extra for it may as well
use it.
Sean
Thats nice and all, but there is still no need to plug in
  #39
Old 11-20-2014, 08:13 AM
MisterCMK's Avatar
MisterCMK
Pop something at start up? What are you talking about?
  #40
Old 11-20-2014, 01:23 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
dont forget to bring your favorite mp3s for the ride there.
  #41
Old 11-20-2014, 04:19 PM
LivingLarge
I received or locally purchased all needed for trip... I'll do an oil change a week out, it better snow!
  #42
Old 11-20-2014, 07:47 PM
Captn B's Avatar
Captn B
Captn B is offline
If it doesn't, you could just keep heading North up to Buffalo, they will probably have some left that you could play in
  #43
Old 11-20-2014, 08:04 PM
05F250DSL's Avatar
05F250DSL
05F250DSL is offline
One more tip as I had to do it this morning. If your door is frozen shut DON'T just pull on the handle. Gently pull the handle with one hand. With the other pull on the bottom or top edge of the door. This way you don't break a handle.
  #44
Old 11-20-2014, 08:14 PM
LivingLarge
Man, the crap you guys have to put up with
2 or 3 weeks per year is all I can handle without my flip flops
  #45
Old 11-20-2014, 10:10 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I am glad you said this.
Some dry silicone spray on the door seals will help then
to not stick. Much cleaner than any of the based oil sprays
like WD40. The wet type sprays pick up a lot of dust and
make marks on pant legs.
Get that on the wife/girlfriend's clothes and you will be
staying home with the dog next time at the long term kennel.
Sean
Quick Reply: Hot EX going to play in snow!
