F250-E4OD problem
Old 11-18-2014, 10:37 AM
FN250super cab's Avatar
FN250super cab
FN250super cab is offline
F250-E4OD problem
HI I just joined this due to ; 1992 f250 7.3 w/Banks turbo -Tranny ISSUE--
E4OD problems are ; (recently purchased w/ this problem)
*O/D light flashes in park- and appears does not cancel O/D driving
*When I got it- very brutal shifts -trans ran cool though...
*Then one day it began shifting as normal.. BUT noticed on the highway longer drives - the trans temp gauge going up - to the edge of red..
*When near hot(stopped)- would not move ahead until it was revved up
*Changed fluid and filter(add Lucas too) and it looked fairly clean- no metal very minimal fine particulate,did find a 10mm nut from stud in pan so put it back on (not sure what it was for but stud spins) not see any way to bolt filter- assume it friction fits?
* Back on the road - after 30-mins driving and tranny working nice - TEMP goes up again - to same area b4 hot (red zone)
*fluid is full and prior was not bad smelling - this tranny had been rebuilt not long ago - and these issues began after that...
** ? Is this the 'trans Control Module' OR previous codes from old issues of worn out tranny??
I have no way to get this rig into the city, nor the cash to put into someone else scratching their head for 3 hours.
(have not looked @ brake lights-hear that may be related somehow- huh!?)
Thanks in advance !
Old 11-18-2014, 11:19 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
The first thing to do is to read the codes. THIS will show you how to read the codes.
Old 11-19-2014, 01:08 AM
r___r's Avatar
r___r
r___r is offline
Welcome to the forum. You have the right guy helping.
Mark K. has helped me in the past.
jordan grant
New Member Introductions
10-14-2014 11:30 AM
Quick Reply: F250-E4OD problem
