95 460 4x4 no power bad gas mileage
So here's the deal. Our trusty Myrtle started guzzling engine oil so in July I got my hands on a really nice looking crew cab with 71000 miles. The truck has a banks trans command and a kenne bell supercharger. It also had the dreaded exhaust leak. We drove her around as is and it was fine except for the smell of exhaust on start up and the noise. I finally was able to bring her in to get that leak fixed by having the local muffler shop install some Thorley headers. They also took the cat out and put in a new muffler. I should have gobs of power right? I can't tell the difference. At least it sounds nice.
I also noticed that my mpg took a huge dump, we're about 500 miles into a 6000 mile road trip right now and I'm getting around 8 with our 2000 lb Alaskan camper and pulling a 1000 lb teardrop trailer. Going 45-65 mph, not many crazy grades. Front tank only, I'm in the process of checking the rear. Before I brought it in it seemed to be closer to 10-11 mpg. The mechanic did do something to the fuel system: he said he noticed that there was an open vent on the front tank which he plugged. The tank is aftermarket. Thanks for reading
One item down....many more to go.
Age/condition of the plugs, wires, cap/rotor?
Air filter?
Tire pressures?
Check for dragging brakes?
Check for fuel tank cross-flow.
Fuel pressure running on the front versus rear tank?
Have you checked the Fuel Pressure Regulator for signs of leaking?
Honestly 8-9 MPG on a 460 equipped truck carrying a camper is not that bad IMHO...
Air filter?
Tire pressures?
chadc2003
03-02-2007 10:48 PM
Bimmer ese
09-08-2003 05:42 PM
