New 6.7 takes forever to warm up
The supplimental heater helps, as does plugging it in. Driving it is still, unfortunately, the fastest way to warm it up.
These modern diesels will not warm up to an operating temp. by idling. Idling at low rpm is very bad for them. If you must idle set up a high idle circuit you probably want about 1200 to 1400 rpm. Some of the more savvy mechanical folks or diesel techs may be able to better explain and suggest a better solution. Best to just idle long enough to get the oil flowing and then drive it. I try to keep under 2000 rpm when really cold and let other people pass.
J/K.....seems the general consensus is to drive her. Seems like the dealers would option those trucks (up North) with supplemental heaters to start with.
Idle on these trucks is only about 300° F EGT temps. Even cruising down the freeway at 70 mph produces only 450-470° EGT. The way to produce heat in these trucks is to put a load on the engine so the turbo boost the compression in the cyclinder.
I find I warm up faster with 5 minutes of normal driving than 10 minutes of idling in the driveway. As everybody else says, just drive it.
Only minimally. When needed, I use a 1,400 RPM high idle as it will produce heat faster to help clear the windows but it will still never fully warm up.
With the cold high idle, the boost will run at 5 PSI for 2-3 minutes as part of the warm up strategy.
High idle while scraping the windows clean and then by the time you drive a mile or two you'll have heat.
With the basic AC/Heater control unit, the recirculate air turns itself off after 5 minutes anyways so if you are gone much longer, you step into a cab of diesel fumes.
Below freezing, I can high idle mine for 20 minutes and it'll maybe reach 170°F. It'll get to 195°F in much less time by driving it.
If you keep fuel records and idle often, you'll notice this engine is not efficient cold and uses what diesel it can to warm itself up and become efficient.
I've been going through the same temps as you lately but I am lucky and have the supplemental heater and heated seats and steering wheel.
One thing I can suggest (which I had on my last F350) is to run an extension cord into the cab in the passengers foot well. There is a body plug under the carpet that you can easily access. I threw in a car warmer and T'd the other end in with the block heater cord. Then once you plug in the block heater it also kicks on the car warmer. It makes a HUGE difference if you don't have the heated seats or other options. Took me probably 30 min to get it all ran and wired. All you need is a 6m extension cord and an extra end because you have to cut the one end off to feed the cord into the cab. In the summer it all tucks up under the dash in the passengers foot well and you never know it's there. Just a suggestion, best of luck.
This may sound like I have no clue as to what I've been driving, but how can I tell if my '11 is equipped (or not) with the Rapid Heat option. I do know that the heated seats are keeping the back side of me warm, it's the front side that stays chilly and that truck seems to take a very long time to get anywhere near normal operating temps when it gets in the teens and below. And the transmission temp seldom gets to the normal 180-200 degrees unless I do extended interstate driving.
#29
sounds like you have it. Check your window sticker.
#30
