Difference from 72' to a 79' motor?
. Not much difference '72 to '82... 1971 400" had more power, higher compression ratio, better MPG... compression ratio dropped in '72... about '74 the exhaust ports got emissions bosses in some vehicle models... cam was retarded... 351"M version added... '78 the blocks were strengthened to prevent cracking...
. Really really suggest just rebuilding your '79 351M with 400" crank to 408"... TMI pistons... non-retarded timing chain setup... modern cam/lifters/new springs... to bring your engine tech 30 years into the future... better throttle response... much more power... better MPG...
peakster
10-12-2014 09:01 PM
Lawrence Taylor
13
07-07-2014 09:44 PM
autojames2002
12-06-2004 09:24 AM
